Results 1 to 13 of 13
Thread: 1981 ATC200 need help please.
    Jul 2017
    Masontown pennsylvania
    7
    Hello everyone, i need help badly. Okay so here it goes, i just rebuilt my trike because it was smoking badly. I put new valves, valve seals, cam chain and rings in it. I put it all back together and it ran great, i did the first heat cycle and let it cool down completely. I went out to re-start it and i broke the pull rope, it seems like the motor is really tight now and i don't know why it is like that . It was a breeze to pull over before the rebuild, now im just wondering if i did something wrong, or is it like this because of the new parts? Any help or suggestions would be greatly appreciated.
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    Is it hard to pull all the time or only on the compression stroke?
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Jul 2017
    7
    Thank you for the reply, it's only on the compression stroke. Once i pull the first three inches or so out of the recoil it's not too bad, it just seems really tight to me. I also have a hard time getting it to fire up now, it used to be a one pull wonder, now i crank and crank on it and only get it to pop. That was before thw recoil rope decided to snap .
    Apr 2017
    McConnelsville,Oh
    157
    is the compression release hooked up?
    1985 ATC125M: Parts
    1988 TRX250X
    Jul 2017
    7
    Yeah it works, im just wondering if maybe i didn't put it in time correctly. Im familiar with the cam timing but not the pulser rotor timing.
    Apr 2017
    McConnelsville,Oh
    157
    Having it out of time wouldn't do that but, just for good measure to adjust the timing line the "F" mark on the flywheel to the mark on the case and then line up the line on the rotor with the line on the pulse generator.
    1985 ATC125M: Parts
    1988 TRX250X
    Jul 2017
    7
    Okay thank you for the advice, how do i go about setting the gap on the pulse rotor? Mine appears to have a fairly large gap, i didn't think to look at it before i tore it apart.
    Apr 2017
    McConnelsville,Oh
    157
    the gap should be about .020 I think but i'm not positive try adjusting your valves to .003 and see if that does anything.
    1985 ATC125M: Parts
    1988 TRX250X
    Jul 2017
    7
    Okay, thank you. I will let you know if this helped or not.
    Apr 2017
    McConnelsville,Oh
    157
    your welcome
    1985 ATC125M: Parts
    1988 TRX250X
    Jul 2017
    7
    The trike is fixed, thank you 125mmadness. I followed exactly what you told me to do and it's now running like a top. �� once again thank you so much.
    Apr 2017
    McConnelsville,Oh
    157
    That's Great! Your very welcome.
    1985 ATC125M: Parts
    1988 TRX250X
    Apr 2014
    Edmond, KS
    2,591
    So did you figure out what it was? Rotor timing, valves? This is for my curiosity and maybe someone else will learn from it too.
