Thread: Air fuel setting help
    May 2016
    Calgary Alberta
    Help with my trx200 (same as 84 200es shaft) when I first bought the bike it was running okay. Cleaned the carb and jets just because who knows when it was done before. I was a little confused when I found the air fuel screw all the way in. When I got the carb back together to factory specs it would bog on a quick shot of throttle but okay if I slowly pressed it. It also would die after idling down a long hill. Doubled checked all my adjustments and everything was good. I slowly turned the screw in giving it quick shots. It cleared up when the screw was all the way in. Should I be worried running like this? What could cause this? Thanks.
    Feb 2017
    Corona CA
    857
    Have you ever checked the actual jet? Could be way bigger than factory? Maybe the needle on the pilot screw is broken? I would say that's not normal. Most hondas are 1.5 to 2 turns out for factory settings. I would also say if it runs well and the plug chop looks good , no backfiring at shut or free rev maybe don't sweat it.
    Onetrackmind's Avatar
    Onetrackmind is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2015
    Allen Texas
    399
    Yep...I agree with what Shawn said. It sounds like you're jetted too fat.
    Feb 2017
    Corona CA
    857
    Scary ^^ lol
    May 2016
    Calgary Alberta
    Quote Originally Posted by Shawn Powell View Post
    Thanks, I'm not sure about the jets, they may have been tampered with at some point, I didn't look too closely at them and haven't had enough of these so don't think k would even notice if they were aftermarket. I'll just take it out for a rip and jeep an eye on the spark plug and see what it's telling me.
    Slidell, LA
    4,738
    Try this. Start it up and see how it responds with full choke vs no choke while feathering the throttle. If it runs good with the air screw all the way in that means you were pouring full fuel and no air. Which means you are jetted lean on pilot or your air screw components need replaced.
