Results 1 to 11 of 11
Thread: How low can you go?
    Oct 2013
    Chandler, AZ
    100
    How low can you go?
    Hello Trike Aficionados,
    I recently picked up a very decent 1983 ATC 185 S, and am fixing it up. I have gotten Klaw XC's for the rears and A Front Max. They are all stock size - 22x11x8's. I have inflated them to 5 lbs which is what the Front Max is rated, and the Klaw XC's are stated as 7 lbs, and are stated as 6 ply with the Front Max as 2 ply. I had a 185 S Thirty or so years ago, and the OEM Ohtsu's seemed to be much more pliable. Mind you, I don't recall checking the air pressure ever really. They would balloon up like a dragster in higher gears (I always imagined that the extra circumference gave a few more MPH at top speed), but I don't think that the Kenda's will do that - at least not at 5 PSI.
    What air pressures do you guys run on similar machines (primarily unsuspended - at least in the rear), and how low can I go pressure wise before they will want to roll under while cornering or won't properly protect the rims against damage?
    Thanks!
    Austin, Massachusetts
    1,591
    twoooooooooo
    Wubba Lubba Dub Dub!!!!!
    TRIKES:
    86 250r
    85 250sx
    86 250sx
    85 Yama 225DX - The Rental!
    150cc Piranha powered 70
    110cc Lifan 70
    82 70
    83 ALT 50 Trail Buddy
    88 Yamaha BW 80
    84 z50
    Oct 2013
    Chandler, AZ
    100
    redsox,
    By saying "twoooooooooo" I assume that you mean 2 PSI?
    Thanks!
    Feb 2017
    Corona CA
    827
    I run between two and 5 in my tires on my 350x. Depends on terrain. I have more suspension though. I'd swap your rears out for two ply when you need to. But I agree with the above. Two sounds about right.
    Apr 2014
    Edmond, KS
    2,591
    Shawn's right. Two ply tires would be way more pliable than 6 plys.
    Oct 2013
    Chandler, AZ
    100
    Thanks for the input guys, I appreciate it. I had kind of come to the conclusion that I probably should have gotten the Kenda Scorpions (2 ply) instead of the Klaw XC's. Live and learn. The Klaw XC's do have good traction though. As I live in the southwest with some jagged rocks, I'll probably be wary to go down to 2 PSI, but I have a good pressure gauge and an inflation gun which I can take along, so I'll experiment and see what gives the best balance of attributes performance wise.
    Apr 2014
    Edmond, KS
    2,591
    Shawn Powell lives in the Southwest too.
    Feb 2017
    Corona CA
    827
    Quote Originally Posted by Bernard3rd View Post
    Don't go with the scorpions for trail riding. They blow. Maybe a good mx tire but they run really small and narrow. Traction was mediocre at best. If you were close I'd give you mine to get em out of my shed. I just bought the maxxis m9209 and went for my first ride yesterday. 2 ply 22x11 and cone in 8 9 & 10" rim options. So far I like em a lot. I'm in so cal and the same rocky trails but I do a lot of woods riding mud sand etc. water crossings. I also just upgraded to beadlocks so I can go as low as I want
    Oct 2013
    Chandler, AZ
    100
    Thanks Shawn, Great info. I kind of wish that the original Ohtsu's were still available.
    Feb 2017
    Corona CA
    827
    I don't know what size your running but I was at chapparal motor sports in San Bernardino (they ship to lower 48) and they had OEM 400ex rear tires 20x11-9 ohtsu 1ply bias belted. Super soft not too aggressive. Was shocked they still had them on the shelf since they haven't been made since 2014.
    Oct 2013
    Chandler, AZ
    100
    I'm pretty set to run stock size to maintain the overall stock look, but that would be a good grab!
