Results 1 to 3 of 3
Thread: Fuel Strainer Remove/Replace (250sx)
    Aug 2016
    vancouver BC
    17
    Getting a very slow fuel drip coming out of an 250sx tank I am restoring, looked inside with a flashlight and the fuel strainer (seen in this image, the straw that lives inside the tank) looks like it needs to be replaced. The petcock is off, and i removed a little rubber O-ring from around the strainer, anyone have a trick to getting these out ? Trying to put pliers on the inside of it and expanding them, tried getting some deep creep around the outside of it, grabbing with pliers etc she won't budge. Hoping to do it w/o damaging so i can try to clean it up and put it back ?
    Apr 2014
    Edmond, KS
    2,591
    If it's coming off that hard, you probably won't be able to save it.
    AMK's Avatar
    AMK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2017
    Shelby, OH
    181
    I wonder if you could find a wooden dowel rod slightly smaller than the od of the strainer and push it through. Then dig it out of the tank.
    I just removed one from a 350x and it had swollen but i cleaned the hole and had enough room to press it back in.
    Alan
    1985 350x
    1984 200es Big Red
    1985 200s (little red)
    1986 200x saga
    2) 1985 350x projects
    And a slew of others to hold my attention
