Results 1 to 8 of 8
Thread: 200x Running Right?
    Jan 2017
    Nebraska
    12
    200x Running Right?
    Does it sound like my trike is running right? It doesn't smoke at all. I just get really paranoid about this thing.
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    sounds ok to me, how does it run otherwise
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Sep 2014
    Oregon
    591
    Stock exhaust? Sounds ok. What is that fluid sitting on top of your bottom end?
    Trikes owned:
    83 Honda 200x "Liquid X"
    81 DG 250r : Sold
    Slidell, LA
    4,738
    Sounds a little clanky, not unusual. Ensure your valve lash is in spec and timing chain isn't stretched.
    Jan 2017
    Nebraska
    12
    That clank is what had me a little worried. I'll go ahead and check that out just to make sure. Thanks!
    Jan 2017
    Nebraska
    12
    x-rider: Yeah, that is the stock exhaust. That was just water. I had just washed my truck and figured I would clean this up too while I had the hose out.
    125Mmadness: It's a little cold weathered and takes a few kicks to get it started but, other than that, I think it runs great. The clank that yaegerb pointed out is what had me a little worried.
    Apr 2014
    Edmond, KS
    2,591
    All I could hear is maybe a little bit of cam chain rattle. It does sound like it may be idling a little bit low. Maybe that noise is just from the low idle.
    Jan 2017
    Nebraska
    12
    I think my carburetor might be a little off. I was planning to do a rebuild on it.
