Results 1 to 3 of 3
Thread: Big bore 125m piston find.
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    Found an NOS 125m 3mm over piston on ebay the other day, I knew they made these but have never seen one until now. I bought a .50mm over high comp piston a few months ago as well so now I have 2 rare 125m pistons. the 3mm over piston also has a slight dome, not as much as my actual high comp piston, but more than stock.
    In the picture the piston order is stock, cb200, 3mm over, and high comp
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Feb 2015
    Cairo NY
    55
    What are the differences between stock and the CB200 piston? Or are they interchangeable?
    Apr 2017
    McConnelsville,Oh
    157
    the cb200 piston gives you tons more compression but you have to modify the skirts on the cb200 piston to clear the counterweights on the 125m crank. I had one in my old 125m with just a stock cam and that thing was FAST compared to when it was stock.
    1985 ATC125M: Parts
    1988 TRX250X
