Results 1 to 1 of 1
Thread: stripped stuck keyway removal
    axeman24 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2016
    long island NY
    247
    85 250r
    I was putting an oem stator in when i noticed my flywheel keyway was very messed up.
    no amount of BFH use helped
    i picked up a tiny cutting wheel for my dremel
    SURGERY TIME
    i had to put the bike vertical and remove the skidplate to get a good angle
    i carefully made a cut down the center of the key
    it tapped out easily after the cut was made
ID:	246470Click image for larger version.
ID:	246471Click image for larger version.
ID:	246473Click image for larger version.
    on a side note i noticed small scratches on my flywheel looks like someone grabbed it with a pipe wrench or something probably why it came loose and spun
    are these scratches something i should worry about on my flywheel
