Results 1 to 3 of 3
Thread: '84 200X Shock Internals Picture
    Jun 2017
    US
    27
    Hi, does anyone have a picture of the internals of a 200X rear shock? I'm rebuilding mine, and just wanting to compare before I put it all back together.
    May 2009
    S.E. Michigan
    1,251
    Assuming you pulled the shock shaft assembly all apart, make sure you align the rebound clicker numbers with the orifices in the shaft nut. The way I did it was to torque the shaft nut (the one with the orifices) first, then loosely attach the clevis (but thread it on all the way). Attach the clicker and set it to 1. Then back the clevis off slowly while watching for the largest orifice to be visible through the slot in the shaft nut. Once it is centered, then lock down the clevis with the circular jamb nut. Once it's all locked down, check that the clicker works correctly and observe the orifices. 1 is the largest, they get smaller for 2 and 3, and then 4 has no orifice at all.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    Jun 2017
    US
    27
    Thank you so much!!!
    Sent from a pay phone
