Results 1 to 15 of 18
Thread: New Yamaha!
    Sep 2017
    Nebraska
    New Yamaha!
    I just picked up a yamaha 3 wheeler for $50, the guy selling said it was a 1982 yt175 but people on here told me it was a 125. It does not run so Im hoping to get as much info on here as possible in order to get it running. first off, Im in the process of taking the engine off but Im only as far as the exhaust. After the engine is off I will be taking it to school and tearing it apart there and putting new rings in it. The guy told me that it wasnt getting any fuel to the cylinder but I have not checked for myself, it does have spark and compression. It has a throttle cable, but no throttle to hook it up to and Im not sure what kind of throttle these came with stock. Here is the link to the craigslist ad that I bought it from: https://lincoln.craigslist.org/snw/d...264703913.html Im hoping someone can help with where I can get parts and what I should do while I have it apart and what I need to do to get it running.
    Any and all help is greatly appreciated. Thanks!
    -Joe
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    Cool! Can't believe you got it for just $50 definitely worth it.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    AMK's Avatar
    AMK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2017
    Shelby, OH
    181
    200 to 50? Good negotiator. That's the way I like to buy.
    Alan
    1985 350x
    1984 200es Big Red
    1985 200s (little red)
    1986 200x saga
    2) 1985 350x projects
    And a slew of others to hold my attention
    Sep 2017
    Nebraska
    I think he really wanted to get rid of it and I really didnt want to pay more than 50 for something I wasnt sure if I could get running, but hopefully with the help of all you fine people I will be able to.
    Sep 2017
    Nebraska
    Also is there anything I should replace/add/upgrade while I have it apart?
    Oct 2016
    Las Vegas, NV
    See if you can get a Wiseco piston set for it. Other than that try the 3 wheeler world parts store here to find a carb.
    hmautocenter.com
    Do not buy a piston kit unless you need one.
    Sep 2017
    Nebraska
    I dont think I will be replacing the piston unless I absolutely have to, is there performance benefits to wiseco pistons or is it just durability or other reasons?
    No benefit whatsoever as long as your stock piston is in good shape and within spec. You might not even have to replace your rings either. When you get it apart, measure the bore as well as the ring gap. If everything checks out, I'd run a quick hone through it and run it. If things are out of spec, then you can decide what parts you'll need.
    Feb 2015
    minnesota
    35
    a good way to increase performance for cheap is a set of boyesen reeds. You can pick up a throttle on ebay. Another thing I did was I got rid of the 2-stroke oil pump and pre mix my gas.
    Sep 2017
    Nebraska
    Quote Originally Posted by tborden3035 View Post
    How do you get rid of the oil pump? Also what do boyesen reeds do/ and how hard are they to install?
    Do not get rid of the oil injection pump. It's very handy not having to mix your gas and the oil injection system almost never fails.
    Apr 2014
    Australia
    580
    Quote Originally Posted by Nebraska_Joe View Post
    Yes, don't get rid of the oil pump! I just fill mine right up and you don't have to worry about it for ages! Also I put in boyesen reeds in mine took no time at all! But make sure you don't damage the intake gasket! I brought the reeds and a spare gasket just in case.
    Sep 2017
    Nebraska
    so what is the purpose of boyesen reeds?
    Reeds are requirement for your engine to run. Worn reeds will not do their job properly. I don't know if your current reeds are any good or not, but for $30 or whatever they are they're usually worth replacing while you're in there.
