Thread: ATC110 tire change. Tips?
    Micahdogg's Avatar
    Micahdogg is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2007
    Illinois
    378
    I've got a couple ATC110's with the two piece rims. Tires are about shot, and at least one of the rims appears to be leaking between the halves. I've heard these are a nightmare to change, so I'm inquiring in advance if anyone has tips on what to do.
    I've done 4 wheeler rims and routinely change MX tires on my bikes...what makes these 110's such a bugger? Also, I'm assuming RTV will seal the two rim halves? Thanks.
    (if you click this stuff, you will see pictures of this stuff)
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    1989 Thunderbird SuperCoupe
    2006 F150 Crew
    May 2013
    Brownsville, Tn.
    1,271
    You should be able to change the tire just as you would on the atv. The only difference is the rim does not have a bead so the tire is a little harder to get off the rim.
    There should be an o ring between the two rim halfs. I would suggest using a tube or definitely use rtv on the o ring when you install the new tires.
    * Nicholson 500 Race Bike *
    I would suggest never using a tube unless it's necessary. Tubes are a huge failure point.
    Micahdogg's Avatar
    Dec 2007
    Illinois
    378
    Quote Originally Posted by Joseph Farrow View Post
    So you can use a regular ATV tire, but it won't ever pop into a bead. It just stretches tight to as it approaches the lip?
    2001 Indian Scout
    2011 KTM 250SX
    1986 ATC250R
    2006 F150 Crew
