Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: 86 200x
    Carthage NY 250r rules
    2,355
    86 200x
    Bought this trike for $150 this past summer.Changed a few things on it.Want to get it in riding condition.It starts with a couple kicks doesnt leak or smoke .Overall pretty solid.Click image for larger version.
    250r rules
    N.E. Ohio
    2,002
    Nice score Good luck bringing it back! IMO it's the "Buddy trike" as in anybody can ride it and have a great time on it. Not over powering handles great light weight good stock suspension. There were some discontinued rear red just sold cheap. I checked the site and they were sold...someone here picked em up fo-sure. https://maier-mfg.com/11981-honda-at...ar-fender.html
    2,355
    I will check out the Maier site for those rear fenders. I have a set of 88 trx 250r rear fenders for it.The clutch needs a little work doesn't have much pull to disengage it .I put a new cable on it.I changed the front fender,tank scoops,and kill switch I have a new seat cover aswell. Tank needs painting rear subframe at the grab bar needs straightning,whole rear brake is missing and the rear carrier has a chunk missing where the adjustment holes are.I want to fix it up for trail riding. I have 2 other 200xs 1.84 and 1.83 auto x plus my 88 Quadsport. and 3 250rs.. This is what it looked like when I picked it up first pic.Click image for larger version.
ID:	246670 Click image for larger version.
ID:	246671 Click image for larger version.
    250r rules
    AMK's Avatar
    AMK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2017
    Shelby, OH
    181
    Good find, I just got one in poorer condition for $160.
    I'd have bought that one.
    Alan
    1985 350x
    1984 200es Big Red
    1985 200s (little red)
    1986 200x saga
    2) 1985 350x projects
    And a slew of others to hold my attention
    2,355
    Iv been working on this and a 84 250r frame over past few weeks.Im only working at my job for 2 hours aday but getting paid for 8 hours.I figured out the clutch problems. One was the fins on clutch basket were grooved .2nd was someone put lock washers under the springs wich cause it to not have much pull to disengage.3rd 2 of the metal plates were together .I put a good set of friction plates in and filed the grooves down.Clutch has good smooth feel. Need to fix a leak in the tank so I can test drive it.
    250r rules
    2,355
    86 200x With trx 250r rear fenders.and
    I soldered a crack in the gas tank.Click image for larger version.
ID:	263099Click image for larger version.
ID:	263098 Click image for larger version.
    250r rules
    2,355
    I started working on this trike again.I put a new carb kit and clutch springs in it.Starts and runs well but the fuel tank is leaking again where I soldered it.I drained it and left the cap off so I can prep it for soldering again. After 32 1/2 years of work I retired on December 31st lastyear.Im going to spend more time on my trikes and home improvement projects.
    250r rules
    jasong_10's Avatar
    jasong_10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2020
    Croghan, New York
    420
    Quote Originally Posted by atc300r View Post
    I started working on this trike again.I put a new carb kit and clutch springs in it.Starts and runs well but the fuel tank is leaking again where I soldered it.I drained it and left the cap off to so it can prep it for soldering again. After 32 1/2 years of work I retired on December 31st lastyear.Im going to spend more time on my trikes and home improvement projects.
    Congrats on your retirement! Enjoy the build.
    Jason
    85 ATC 250R - restored stock other than 18" rears, nerf bars, Honda key switch, 14T front sprocket, and white tank and plastics (except rad shrouds)
    87 ATC 200X - restored stock other than 18" rears and nerf bars
    84 TRX 200 - rough but complete budget restore for wife and eventually daughters to bum around on
    Eton Viper 50cc - oldest daughter's current ride
    2,355
    Quote Originally Posted by jasong_10 View Post
    Thanks Jason. A couple pics of the springs the shorter spring is the old one.Click image for larger version.
ID:	267183 Click image for larger version.
    250r rules
    jasong_10's Avatar
    Apr 2020
    Croghan, New York
    420
    Cool, I've never been in either of mine.
    Jason
    2,355
    I soldered the tank on this again and it started leaking again. I'm going to try brazing it next hopefully that will do the trick.I need to get a bearing carrier for it and rear fenders.
    250r rules
    I soldered the tank on this again and it started leaking again. I'm going to try brazing it next hopefully that will do the trick. I need to get a bearing carrier for it and rear fenders.
    IDK if you can learn anything from my experience but: When I tried brazing the same tank (not that it matters) it just kept cracking. I kept the heat as low as possible when fast high heat would get too hot too fast. I used brazing rods with flux on the rod itself. For some reason the tank not only had some tiny holes, it had some cracked areas, and they just kept extending as I braised it. When I did this it was for the 20 day Trikefest historic build and it was the day the guys were leaving, I was braising until they pulled in my yard, it was all I had for a tank or all that effort was a waste of time. If I had drilled a hole in the end of each crack it would look like a pin cushion, it's possible I just overlooked something, that was either 2005 or 2008.
    Honestly, I was gonna try silver solder if I ever did another but if you didn't have much success IDK if I will either but I wanted to share my braising adventure....
    RAD Manufacturing is back operating and he makes a new billet carrier for the 86/87 (I dealt with them thru Facebook). He told me they'd be 200$ but I think he's a bit higher now, fortunately I still have a couple NOS and used ones kicking around. Somebody could modify an existing CNC program easily to reproduce that carrier...
    2,355
    I watched a video of a guy soldering a motorcycle gas tank using a soldering iron it worked well.I may try that or liquid steel.Last measure would be some sort of tank liner.
    250r rules
    jasong_10's Avatar
    Apr 2020
    Croghan, New York
    420
    Can't help with the tank or the carrier, but I do have the fenders that came on my 87. Not sure what you're looking for, they a little rough around the edges (literally, lol) but if they're anything you'd be interested in just let me know.
    Thought I had some pics on my tablet but I must have deleted them . . . I'll try to snap a couple tomorrow if you want?
    Jason
    2,355
    I'm looking for a set for a rider if you could post up some pics that would be awsome.Thank You.
    250r rules
