Results 1 to 3 of 3
Thread: 81 Honda ATC 185s Transmission Questions?
    May 2013
    Washington
    18
    OK. Hello. I have a Honda 185s that is in need of a rebuild. Can anyone possible point me in the direction of a lower end rebuild kit for this trike? or atleast a list of possible wear items I might want to replace? Im already planning a big bore kit on the top end but want to replace the clutches and stuff on the lower end. So any info of what the most needed replacements for the transmission and lower end would be would be helpful. Thank you.
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    Well, the clutch plates are probably in need of replacement. That's about it unless there are any other noticeable issues. I guess your could replace the centrifugal clutch shoes as well but if the bike still bump starts and engine brakes they should be fine.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Feb 2017
    Louisiana
    33
    The only other possible thing, check crank play, and gear wear..
    1985 ATC 350X working progress
    1983 ATC 200X for sale
