Results 1 to 7 of 7
Thread: OEM vs Aftermarket question
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    OEM vs Aftermarket head gaskets, which is better? Honda ATC200M. I have read not so good things about aftermarket head gaskets.
    I think aftermarket should be ok for the cylinder base gasket and rocker cover gasket, etc, right?
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Slidell, LA
    4,738
    Go with OEM, Cometic or Vesrah.
    I just want to add one thing and wonder whether it is a problem or not, because It's been a problem for me.
    I have had a couple Vesrah all metal headgaskets blow on the 200X before it was 13.5:1.
    I just kinda like the metal ring for the combustion chamber and gasket material elsewhere.....
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    So then the cut down beer box gaskets are a no then?
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Jun 2015
    Oklahoma
    732
    Quote Originally Posted by RUNMEDOWN View Post
    Not for head gaskets. But I have used cardboard gaskets before too, they work great for some stuff.
    Thanks for the info. Had previously bought a set of Vesrah gaskets and the worked great for the clutch cover. I think I will go OEM on the head gasket and use Vesrah on the rest.
    Probably OEM on the valve seals, or does it really matter?
    Da velder
    Feedback:
    6,819
    I would take a Vesrah head gasket any day over the new style all metal head gasket Honda is giving us now .
    The Vesrah is exactly the same as what came on your bike when new .
    Quote Originally Posted by BarnBoy View Post
    Jun 2015
    Oklahoma
    732
    Ok.... whats the difference? Isnt the Vesrah all metal too? Does all metal not seal as well?
    (I guess I better get the gaskets I have out, havent looked at them in a while.)
    Da velder
    Feedback:
