Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Torque wrench advise
    Soutwestern PA
    2,040
    My elbow clicks at 5 newton-meters and then again at every 5 n-m interval until my shoulder pops out of joint at 100.
    But seriously, I got a $50 Craftsman 3/8" drive model about 20 years ago. It has handled every trike job I've ever needed. Only thing it doesn't do is go high enough for my truck lug nuts. Mine can be set at 1 ft-lb intervals.
    The beauty of ATCs is that in the manual, it always give s a torque range (19-24 fps, for example), so you don't have to get them perfect. Just somewhere within the range. I normally err to the low side since I have a tendency to overtighten and strip. A cheap Harbour Frieght (or Canadian Tire) tool should serve you just fine.
    Also worth restating, back it the whole way off to zero to completely unload the spring tension after each use. This is a safety concern too.
    Dec 2012
    812
    Thanks again guys. Good tips, especially about backing off and resetting to zero. Keister I'm surprised you know about Canadian Tire! ha ha
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
    Soutwestern PA
    2,040
    Quote Originally Posted by Big G View Post
    I have lots of Canadian friends - most of whom I met on this site. I also know about Kraft Dinner, chip nuts, and panzerotti.
