Results 1 to 15 of 16
Thread: 84' 250r
    Nov 2017
    Florida
    47
    84' 250r
    I have a 250r that idles great but when you go to take off it Boggs down any ideas as too why this is
    Sent from my SM-G955U using Tapatalk
    Oct 2017
    Hutto, TX
    75
    Is it jet properly? Main jet?
    Nov 2017
    Florida
    47
    Quote Originally Posted by spacerust View Post
    I believe so
    Feb 2017
    Corona CA
    833
    Clogged carb , bad jets, improper jetting, fouled plug , bad reefs, dirty air filter , I’d start with the easy stuff. New plug and disassemble the carb and clean it. Clean filter while your there. See what happens.
    Nov 2017
    Florida
    47
    Quote Originally Posted by Shawn Powell View Post
    Dude I even boiled the carb
    Carthage NY 250r rules
    2,355
    Try replacing the coil.
    250r rules
    May 2016
    OH Canada
    1,102
    Check airflow. Make sure the intake is clear.
    Heard a tail of a mouse nest in the exhaust restricting flow. Engine is just a air pump.
    '83 200X
    Slidell, LA
    4,738
    Quote Originally Posted by truckerlump View Post
    There are many reasons why this could be. Are you a new owner of this bike or have you owned it and you changed something and now it acts like this?
    Nov 2017
    Florida
    47
    No I'm a new owner
    Feb 2017
    Corona CA
    833
    How did your reeds look? Those are typically cheep if the look worn or have frayed edges I’d swap em out. Make sure your jets are clean and your fuel to oil mixture is correct.
    Nov 2017
    Florida
    47
    32:1
    Slidell, LA
    4,738
    Raise your needle clip one notch and see if t gets better.
    Oct 2017
    Hutto, TX
    75
    @truckerlump
    You are going to get a lot of good advice here...the more you become familiar with your trike, the better troubleshooting will be. Personally, whenever I get any used motor, whether it's a vehicle, boat or trike, regardless of what the previous owner had said he had done to it, I will always go through basic maintenance to alleviate any unknowns (clean the carb, change the oil, filter, etc.). For now, it starts so that is a good thing, but go through the basics and this should point you in the right direction.
    Nov 2017
    Florida
    47
    They are brand new I've been mixing my fuel at 32:1
    Apr 2002
    s.w. michigan
    6,498
