Results 1 to 12 of 12
Thread: honda atc 200M updating problems carb !!!!
    Sep 2016
    saint pierre and miquelon
    26
    hello i am rebuilding my 84 honda atc 200 m , with a WISECO 10.25: 1 , a UNO air filter and a black DG exhaust, i know that the main jet original is a 95 but i would like to know what size of jet I must use for this .....Thank you for your help ...!
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    It depends on your elevation but, I would start with a 200x carb because it is 2mm bigger and will suit your mods well. What is your elevation?
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Sep 2016
    26
    100 meters only ..! i bought a new mukini carb on eBay so when i full throttle the motor run out !
    Jul 2013
    USA
    737
    You bought the same size carburetor as a replacment? Was the origional a Keihn, just asking.
    Sep 2016
    26
    yes it's the same 22 mm , original is KEIHIN ...
    Jan 2013
    minnesota
    5,911
    If you are using the original factory carb, I would try a 110 then try different positions on the needle clip and check plug color after after around 20 minutes as long as it runs decent. I would also possibly try a one size bigger pilot jet.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON OR A STAR
    Sep 2016
    26
    yes original carb ( but i have a new mukini from eBay here) i ordered 100 ,105 and 110 ,118 pilot jet ( i have only 3660 full rpm)
    Nov 2017
    South Yorkshire
    6
    Aren't the Pilot jet sizes for Mikuni much small for the Keihin Equvilent? So like a 38 Keihin pilot jet is a Mikuni size 17 or something?
    Sep 2016
    26
ID:	247496hello i have a new carb (JIELLI 27mm on ebay) is it better or should I keep the old one? if i use a new jielli 27 mm carb ,what pilot jet should i use please??? (video with 118 main jet )
    -https://www.ebay.fr/itm/Carburetor-FITS-HONDA-ATC200M-ATC-200-M-1984-1985-NEW-Carb/270920908086?hash=item3f1424fd36:g:5eEAAOSwPe1T6kh b
ID:	247493Click image for larger version.
ID:	247494Click image for larger version.
ID:	247490   Click image for larger version.
ID:	247491   Click image for larger version.
    Sep 2016
    26
    Good evening I tried everything with my carburetor JIELI ebay but nothing goes to the nozzle 128, I dropped and I come back with my original carburetor ..!
    Sep 2016
    26
    With the oem carb the 105 main jet i have 6000 rpm . the motor run good ...! is this correct ?
    Sep 2016
    26
    it' s no good very bad i must change my carb for higher what's size ??
