I've never thought about this problem from your perspective, but I have a couple thoughts:
1. Your looking for CFM = cubic feet of air per minute. I think your math is wrong. 200 cc is 0.007 cubic feet. If I use your 12,000 RPM (Waaaaay to high for this engine) keep in mind you only get 1 intake event for every 2 revs of the crank. So you move 0.007 cubic feet of air for every 2 revolutions of the crank. Just multiply 0.007 * 12,000 and divide by 2 = 42 CFM. At a more reasonable 8000 RPM, you would get 28 CFM.
2. The flow through a duct is not simply a fixed number. It will be a certain flow rate at a particular pressure differential. You won't get flow without a pressure difference across the duct. So, the flow rate of the factory intake system is not really something easily calculated without some flow analysis software or a flow bench.
- Frank
1984 200ES Big Red
1985 350X (x2)
1986 350X
1986 250SX
1984 Auto-X
1984 ATC70
1985 ATC70
