Results 1 to 3 of 3
Thread: 1986 350x big bore or stroke or bigger motor?
    Sep 2016
    Pima, az
    11
    I have a 86 350x that won't start..(thinking it needs a top end) I want to make it a hot rod. I don't really know my options.. any advice would be greatly appreciated...
    Jan 2013
    minnesota
    5,911
    what exactly do you mean by hot rod?
    a big bore kit is the easiest and cheapest but you will need to improve head flow to get the most out of the bigger displacement.
    bigger carb, bigger cam, aftermarket pipe (it will be loud), stiffer clutch springs etc. I would also use an mls head gasket from cometic.
    good oil and bigger or additional oil cooler.
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON OR A STAR
    Hyndman PA
    1,905
    I have 3 stages of kits, std- .040 11.5:1 over bore with stage 1 cam , valve and clutch springs that run on pump gas. My .080 over 14:1 stage 2 cam, valve and clutch springs, then our 502cc 11.5:1 stage 2 cam, valve springs and monster clutch springs. I also have 3 stages of port & flow and big valve CNC ported heads, custom pipes 400ex carb kit or 450r carb kit for the 502 kit. also a hirev CDI with a different timing since the stock one retards at 6500rpms. And HD rod and crank ballancing.
Name:	2006-03-03 19.12.11.jpg
ID:	247527Click image for larger version.
Name:	2006-02-27 03.52.10.jpg
ID:	247528Click image for larger version.
Name:	2006-02-27 03.51.11.jpg
ID:	247529Click image for larger version.
Name:	2006-01-27 18.49.20.jpg
ID:	247530Click image for larger version.
Name:	2006-01-27 18.47.58.jpg
ID:	247531Click image for larger version.
Name:	2006-01-02 17.06.56.jpg
