200m Battery wiring
I'm a little confused as to where the positive and negative battery terminals connect. My bike has everything there but the the terminals were completely removed when I bought it. The wiring diagram isn't overly clear. If someone has a picture or could better explain it that would be great.
The positive terminal has the connector with the fuse and the other connector, I don't know where the fuse positive connects nor where the main positive connects (is it to the starter relay? Next to the regulator?)
Does the ground just connect to the frame? Or is there a specific spot?
Thanks
Sent from my Moto X Play using Tapatalk
Most likely not needed any answers by now but just to add some info. to the question.
The positive has two cables:
a) the thin wire goes to the 7A Main fuse (inline white case protected by black rubber)
b) Starter relay left post and the cable on the right post of the relay goes directly to the starter
The Negative cable is attached to the head with a bolt for an engine ground
This is for a 200M.
//ArrowChat Integreation Code
