I got a person that wanted to integrate the Goki starter wiring into the main harness and while researching, it seems it uses the tail light wiring to charge the battery, which runs though a diode for that AC to DC conversion. The manual says to plug into the yellow wire, however the 350x harness doesn't have a yellow wire in the whole harness, but based on smaller models, it's the main power wire from the stator. The 350x harness however doesn't have that wire there (White with Yellow strip), it's only at the handle bar switch plug, regulator, and stator. Do people normally plug it into the brown wire which only charges the battery while the lights are on?
Also is there any info out there on which diode is used or a comparable one? I'm not super up on top of electronics, wiring isn't a problem though lol.
If that's the case, I'd be making an "upgrade" harness that would always charge the battery while the engine is running. Seems like other's with the Goki kit might be interested in the same results.
Thanks for any feedback!
EDIT:
I haven't seen any photos posted online of the diagrams, so here's some photos. Not the greatest, hopefully getting scans soon.
Starter solenoid/relay is part number 892-1221-210 for what he's using, it seems to be the same layout as the diagrams, not sure if it's the stock one or not.
