Thread: 85 atc 250r 38mm keihin air striker jetting
    Mar 2017
    Levittown
    6
    85 ATC 250r
    I'm having trouble with jetting a 38mm keihin air striker
    It's breaking up and cutting out on acceleration.
    I get a little of GO at 1/8 throttle but i have to turn the fuel/air all the way out and its super lean.
    I tired all the jets.
    This is what i have...
    Bored 50 over
    Main jet 178,180,182
    Pilot jet 50,52,
    Needle 3rd notch
    Gold series exhaust
    Carb spacer
    Vforce reed
    NEW items
    Stator
    Cdi box
    Voltage reg.
    Coil
    Compression test 182 psi
    I don't know whats next?
    Slidell, LA
    4,738
    What is it in Hempstead right now? ~35-40 degrees?
    Start with a 52 pilot. Main should be around 172. Take off carb spacer and run full airbox with filter.
    Your airscrew should be between 1-2 turns out. 1.5 is the sweet spot. The bike should come on strong and go back to idle quickly when tuning for your pilot jet. More than 2 turns out on airscrew go with a bigger pilot. Less than 1 turn out on airscrew go with a smaller pilot.
    Slidell, LA
    4,738
    Full airbox will promote a rich condition and he may be able to get away with a 52 pilot if it’s the largest he has on hand.
    axeman24 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2016
    long island NY
    247
    thats real good info with the hang throttle i think thats the problem on my 140/70 im running a 200x carb and it takes a bit to get back to idle may need a different pilot jet
    matt hempsted ny? im in islip terrace i have a 38mm airstriker in the mail for my 85r from greg huntly who will help me with jetting it
