Results 1 to 4 of 4
Thread: Custom ATC 70 support stands
    oldoo's Avatar
    oldoo is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2017
    Australia
    155
    So I had to make a metal project for my capstone unit at UNI, so I decided to build some custom atc 70 stands. The rears are laser cut plates welded together with an outer and inner sleeve. The cups were machined on a lathe to match the axle crush tube diameter then cut in half. The inner material for the rear axle stand is a plastic with low friction (UHWPE from memory) so that you can rotate the axle/wheels easily whilst on the stand. I machined some brass pins with a knurl for some aesthetics. For finishing they got powder coated. Here's some pics.
ID:	247957Click image for larger version.
ID:	247958Click image for larger version.
ID:	247959Click image for larger version.
ID:	247960Click image for larger version.
ID:	247961Click image for larger version.
    Jul 2016
    Pennsylvania USA
    65
    Wow amazing any chance I can get you to make me a set[emoji23]
    ~Matt Gusciora
    Feb 2014
    Victoria,Australia
    878
    hey mate where abouts in aus are ya?
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    oldoo's Avatar
    May 2017
    Australia
    155
    Quote Originally Posted by jakep53 View Post
    Sydney Mate
