Thread: ATC 110 clutch problem
    Oct 2017
    Hutto, TX
    75
    I was trying to adjust the clutch on my ATC 110 and at the time didn’t have the right wrench and used a socket. I loosened it up and then realized that I needed to keep the screw stationary. Now I don’t know how to go to an initial setting. I have it in neutral but the rest axle won’t move. Any help?
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by spacerust View Post
    Συγνώμη, αυτό μου φαίνεται σαν το ελληνικό. Παρακαλούμε την αίγα σας με χαρά στη βουβωνική χώρα.
    ΠΡΟΗΓΟΥΜΕΝΟΣ ΔΙΕΘΝΗΣ ΕΡΓΑΣΤΗΡΙΟ ΕΡΓΩΝ ΕΡΓΩΝ ΕΡΓΩΝ ΚΑΙ ΕΡΓΑΣΤΗΡΙΟ ΤΜΗΜΑΤΟΣ atv ΚΑΙ Ο ΜΟΝΟ ΠΡΟΣΩΠΟΣ ΣΕ 3ww ΧΩΡΙΣ ΚΟΥΜΠΙ edit Ή ΑΣΤΕΡ
    Nov 2015
    Davenport iowa
    1,144
    Adjust center screw counter clockwise till you get a little resistance and then back a 1/4 turn clockwise and then lock it back with the nut while holding the screw..
    If you have cranked that screw down you may need to loosen it a bit more and then follow above steps..
    Oct 2017
    Hutto, TX
    75
    Okay. I will try that. I appreciate it
