Results 1 to 11 of 11
Thread: 250sx with 200x front end rims tire set up
    Feb 2015
    new york
    86
    can I run a bear claw tire up front with 200x front end,or is it to wide and will rub?want to run bear claws in back what are the sizes??
    Apr 2014
    Edmond, KS
    2,591
    The stock front tire for the 200X is a 23.5x8-11. If you can find a Bear claw in this size, it should work fine. The rears on both machines were 22x11-8 stock. If not, there has been a few people who have put a 10" rim on the front of their 250R. Maybe this could work on a 200X front end as well.
    Feb 2015
    new york
    86
    having trouble locating a aluminum front rim??
    Apr 2014
    Edmond, KS
    2,591
    What size? There's several stock ones on Ebay right now.
    Feb 2015
    new york
    86
    Looking for a new aluminium one .
    Feb 2017
    Corona CA
    858
    Quote Originally Posted by vanvranken View Post
    Call Douglas rims , they sell new ones I have one both 11” and 10” for my 350x , same volt pattern offset etc as the 200x. Also check ebay there’s a guy in so cal who usually has them in stock. That’s where i bought my 11” one from.
    Sent from my iPhone using Tapatalk Pro
    Feb 2015
    new york
    86
    I found the rim on ebay.listing says it fits 350x,200x,250r.i tried my 85 200x hub on a 86 250r front rim I have don't fit????
    Feb 2017
    Corona CA
    858
    That’s strange. I was under the impression they were the same. I was even told the rims I had on my 350x were OEM 200x wheels, wich made sense cause they didn’t look the same and the tears were 8”.
    Feb 2015
    new york
    86
    I might have been sold the wrong front hub.not sure how to identify it????the ebay listing said came off a 85 200x.Click image for larger version.
ID:	248098Click image for larger version.
    Feb 2017
    Corona CA
    858
    Everything I’ve read said they swap. Maybe you have the wrong hub. Idk. Measure it center of stud to center of stud then multiply by 25.4 , should be 170mm , at least that’s what I’m reading.
    So there might be a difference from 85 to 86 on the hub and wheel. I’m reading the 85 is 4 on 176 and the 86\87 is 4 on 170. Hopefully someone can verify. I don’t own either bike. Only a 350x good luck
    Last edited by Shawn Powell; 12-03-2017 at 10:44 PM. Reason: Typed wrong. Fat fingers
    Feb 2015
    new york
    86
    help anyone???
