Results 1 to 8 of 8
Thread: Rebuild 1982 ATC 250
    Dec 2017
    Central California
    I just picked up a 1982 ATC 250 from a buddy of mine who is going to help me build it out as 2 wheeler. Seeing how missile kits are so hard to come by nowadays we figured we could fab one up using existing drawing and such. Does anyone have any dimensions they would be willing to share?
    Also, I took the motor off and it is FILTHY. It runs OK, it doesnt idle and I think there might be a crack in the transmission housing, do you guys think it would be worth doing a complete engine tear down to clean it up and make sure its in working order? The carb will need to be rebuilt for sure but I just don't know if it would be worth the hassle of a complete teardown would be worth it.
    Thanks in advance!
    Oct 2017
    Hutto, TX
    75
    If you have any parts that you are looking to sell off of your 82, let me know, I would be interested.
    Jan 2014
    La
    1,062
    yea the engine is more than likely rebuilding as long as the block isn't cracked like you said the old honda 200 are tough old engines.
    Slidell, LA
    4,738
    Quote Originally Posted by iflywhirlybirds View Post
    Thanks in advance!
    I assume you mean an '82 250R? I may be incorrect, but missile kits were not made for the 1st or 2nd gen's. I believe they were only made for the 85/86 250R so any attempt to make a missile kit would be on your own or from schematics by another enthusiast.
    Dec 2017
    Central California
    Quote Originally Posted by spacerust View Post
    Are you looking for anything in particular? I ask because we might get a bit Hannibal on this build.
    Also thanks everyone for your replies!
    Jan 2013
    minnesota
    5,911
    Thanks in advance!
    Ok, so you have a used engine that you don't know the condition of that only runs "ok" and it doesn't idle and it may have a crack in the center case and you want to know if it is worth spending around a total of 8 hours tearing it down, inspecting and reassembling it with any new parts it needs while you are willing to spend several weeks modifying the frame?
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON OR A STAR
    devore,ca
    1,054
    I haven't ever talked to anyone that was all that happy with their missile. They don't handle for crap. Something to think about before you go building a swing arm, figuring out how to get a sprocket mounted to a wheel and don't forget about the idler gear set up you would most likely have to come up with to move the chain over. There is a lot going on there.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Carthage NY 250r rules
    2,355
    A member on here used a BW 350 swingarm on a 2 wheel Tecate.
    250r rules
