Thread: Jetting help again if you all would be so kind.
    Southern utah
    11
    1985 atc 250r. Just rebuilt my top end with a 68.50 big bore, port and polish from bdt motorsports. And a Boysen reed block. Stayed with pump gas didnt want to deal with race fuel. I have a fatty fmf exhaust (probably needs new packing) . Stock carb bored to 36mm. (I have plans for a 38 or 39 mm but cant afford atm). I have a nology spark plug hotwire and dont know if it matters a wiseco billet clutch basket. I would like to run stock box and lid due to mostly dune riding. Uni air filter.
    Elevation is about 3000ft
    Temp for winter 30f to 80f
    Summer 50f-115f
    Current main jet is a 180( bdt recommended 170-172. 180 was on hand).
    Pilot is 52
    Airscrew 1.5 turns out.
    Stock need 4th clip from top
    Can't get past 1/3 throttle before bogs and loses powerband. Any advice would be greatly appreciated.
    Currently going through break in process.
    85 250r
    82 250r
    89 xr600
    85 250 es big red
    Still not enough
    Jan 2013
    minnesota
    5,911
    The word bog is utterly meaningless when attempting to describe how an engine performs.
    Take a high resolution photo of the plug from fairly close and post it.
    White is way lean
    Lite tan is typically close.
    Dark brown is typically too rich but could also be burning oil.
    1. When it "bogs'', does it hesitate somewhat and burble/run rough for a second or more?
    2. Does it hesitate like it is out of gas but does not burble?
    3. What is the compression when you kick it over quickly 3 times in a row with the throttle wide open?
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR AND THE ONLY PERSON ON 3WW WITHOUT AN EDIT BUTTON OR A STAR
    Aug 2015
    H B
    103
    Put the clip on the needle in the middle.
    Sent from my iPhone using Tapatalk Pro
    Slidell, LA
    4,738
    with airbox/lid I would run a 164 Main, 48 pilot and clip 3rd from top.
