Thread: 200x rear wheels
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    436
    200x rear wheels
    I am wondering if the 8 inch wheels from a first generation ATC200x will fit on a TRX300ex? I know the bolt pattern is the same but being that the 300ex uses a 9 inch wheel I was not sure if the 8 inch 200x wheel will fit the rear 300ex hub.
    Sep 2014
    Gresham, Oregon
    140
    I believe the bolt pattern is the same but I think the lug bolts on the TRX are larger diameter. When I bought my 1st gen 200X, the guy threw in an extra set of rear wheels with some old tires mounted. When I went switch out and use them instead of the originals I found that the bolt pattern was the same but the bolt holes were too large. I was told they were probably for a TRX or a 350X and if I wanted to use them I needed to switch out the hubs for a TRX.
    Feb 2017
    Corona CA
    858
    All the same. Just make sure you have the correct lugnuts.
    Herboso your holes were probably to large because the inserts had fell out. The OEM wheels have inserts in them to allow for tapered lug nuts. They fall out all the time. Then the holes are way to large.
    Sent from my iPhone using Tapatalk Pro
    Jun 2013
    Oceanside, CA.
    613
    Almost all Honda 4 on 110 bolt pattern use 10 mm nuts/studs. I can only speak about the '83 original 8 inch wheels, they have a smaller wheel center diameter, where the flat bolting face plate is welded to the wheel id. Your 300ex hubs OD maybe too large for the 200x wheels. They can be cut/machined down to fit. Back in the day when I got my first 350x wanted to use the 10 paddle tires off my 200x found this problem, Honda made the hubs larger when they went to 9 inch wheels.
    "HJ" Click image for larger version.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    436
    Quote Originally Posted by HairyJR View Post
    Thanks. I was thinking that I tried 200x wheels on a 350X back in 1991 and there was an issue with fitment but I just could not quite remember. Your post sounds exactly like what I saw back then.
