Wheeler pulling hard to the right on pavement?
Very feasible for two tires to have two different contact patches and track straight with two different pressures. I've seen it many, many times. My current SX rider I've been riding for over five years still has the original OEM Ohtsu 22x11x8 pro-vectors. From the time I got it, if you filled both rear tires to the same pressure, it would always pull to one side. This is because one tire is slightly larger in diameter than the other, and that's most likely due to one tire having been over-inflated at one point or another.
You are looking to match the circumference, not the pressures. I had to get used to one of my rear tires being lower in pressure than the other because now when you're turning the two tires will behave differently depending on which way you turn, but I have no problem dealing with that and I'm far more concerned with the machine tracking straight.
Buying a new tire will likely help if the existing tire that you're keeping is a fairly new tire, but even still, there could still be a difference in tire diameter between the two because they're from two different batches and one has been ridden on as well as inflated for some time now.
Regardless of what you do, it's very simple to just fill one tire or deflate the other until the bike tracks straight.
