Results 1 to 7 of 7
Thread: Restoring switch housings
    The Open Road
    4,736
    So I've got myself a junk handlebar switch for an 86R I got for ten bux. The housing was decent with a little fading but the engraving had lost some of it's white and red paint.
    I have brand new switches to go inside the housing out of an NOS Honda TRX200 switch which I can easily adapt for the R.
    How many different ways can I darken the faded housing a bit. Black paint? Clear coat maybe? Rit Dye?
    I don't want to rub oil all over it or armor all because those are relatively short term remedies and I also have be careful not to affect the red and white paint after I repaint those areas.
    Whose restored or rehabbed black handlebar switches and what did you do?
    Pics too if you got them.
    This is what I'm working with....it looks more faded in person.
    The Open Road
    4,736
    I'm putting the guts from this in there.
    I got the idea from someone here.... smvorndran or similar spelling
    Jul 2016
    Pennsylvania USA
    65
    I do this somewhat often and for most of my customers they like it. I strip the housing and sand it with 80 grit but barley. Then I have this almost plasti dip type paint that’s either satin or matte depending on the switch and I paint with that. It isn’t the exact same texture at the original plastic but it’s very black and looks new. The good part is it’s a thick paint kinda like bed liner. I forgot the name but when I go to my shop tomorrow I will tell you
    ~Matt Gusciora
    devore,ca
    1,042
    Clear spray paint the whole thing.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    The Open Road
    4,736
    Quote Originally Posted by BOB MARLIN View Post
    Will the clear darken it a little?
    devore,ca
    1,042
    It will a bit. Kinda looks like its been armor all'ed. Make sure its clean or it will get "fish eye" all over it.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Aug 2015
    Idaho
    842
    Plastic renew is what I used. Sanded it with 600 & 1500, scrubbed with 4/0 steel wool, applied plastic renew and buffed it with a soft cloth. I decided to paint the lettering one color. It has held up good imo.
    As a side note, I bought it for the fenders, but found it to work awesome on all the plastic and rubber cable/wiring boots.
    Best of luck chop and Happy New Year!!
    https://www.motosport.com/product/?a...segment=badger
