Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: Im "throwing in the towel" on this Tri Z
    9,020
    Quote Originally Posted by Racer-X View Post
    Well, when I was installing the jug I was able to look in through the intake port and see that the rings where exactly centered in their correct location on the pins. One actually moved just a little bit and the jug wouldn't slide on. I went in through the intake port with a screwdriver and spun the ring a little bit to the correct position and the jug slid right on. Then when I pumped the kick starter and cycled the engine before I put the top onto the jug it sounded and felt smooth as butter. Also I was having this exact same issue before I rebuilt it with the old piston and rings. It quit running and was doing the same thing. That's the whole reason I rebuilt the top end in the first place.
    If I’m understanding your post above you’re saying that with a ring in the wrong position you managed to get the piston far enough into the cylinder to see and move the ring through the intake port? If so it is possible that you broke or damaged a ring. Not saying that’s your problem, but if I was you I’d pull that cylinder off and check.
    It sucks to get old
    Jun 2014
    Pittsburgh
    107
    when your 250r was doing the same thing and it ended up being the coil were you still getting spark from the plug? Because I get blue spark no matter what plug try. I'm only asking because I have only had to replace a coil one other time before but when I did, I wasn't getting spark at all.
    '' Mixin gas N haulin _ss''
    1985 250R-310
    1985 Tri-Z
    1985 Tri Zinger-X's 4
    1973 atc70
    Mar 2008
    Tug Hill
    1,282
    El Camexican i think what he meant is how sometimes when you put the cylinder on the rings can stick out and get caught on the intake port. i think hes just saying he had to push the ring in to get past the port. i know he kinda explained it like it wasn't lined up but sometimes it can be a little too far one way and you gotta spin it a tad to get the side stuck on the port to fit. its playing with fire when these rings catch on the port like that but i think he got it because if hes getting that much compression I'm thinking the rings are ok. thats just my thoughts on it.
    re-reading the post i thought it was only running for seconds but i see it says a few minutes so i don't think its the flywheel key, it still could be electrical I've seen cdi's work till they warm up then go out. doing a test on all the electrical components couldn't hurt. just let me know if you need the specs.
    Last edited by lndy650; 01-01-2018 at 12:03 AM. Reason: added a few commas and such
    9,020
    Quote Originally Posted by lndy650 View Post
    That's not what I'm reading in his post. As well, one good ring will give just as high a compression reading as two (some engines use only one) Lots of variables come into play when doing a compression test, including the quality of the gauge, but 155# isn't much for that engine. I just torn down a stock Tri-Z engine that had damaged rings and still gave a reading of 165#
    Again, I don't think this would be causing his running problem, but I'd look at it again if it was mine.
    It sucks to get old
    Mar 2008
    Tug Hill
    1,282
    ya i hear ya you could be right. i just cant see how someone could shove a cylinder over a ring thats not seated properly but i guess it can happen. and ya i agree one ring can make good compression all im saying is i dont think compression is an issue here.
    i wasnt tryin to say your wrong sorry if you took it that way im just thinking of all possibilities
    im not new glamy ive been here longer than you. another thread youve now hijacked and given zero help
    Dec 2017
    Over here
    26
    Connecticut
    1,605
    Anyone else concerned with 28 to 1 mix? I would run closer to 50 to 1 on your rebuild. Too much oil in your gas mix will affect the air/fuel ratio.
    The Open Road
    4,736
    Quote Originally Posted by sledcrazyinCT View Post
    I'm still wondering about 155# compression. That seems too low to me.
    9,020
    I don’t know exactly how it might have been done, but I’ve broken a couple rings trying to load some four cylinders up.
    You never know who your dealing with on the Internet, but I’m sure somewhere out there is a guy that has used a deadblow to get a cylinder over a tight piston at some point.
    It sucks to get old
    9,020
    Racer X, you made the comment that “it pumps fuel for a minute or two and then stops”. Once the float bowl on a properly working carb is full the fuel is supposed to return to the tank via the return line at the grey plastic tee under your seat on the RH side, so you’re not going to see fuel flowing into the carb through a clear line if that’s what you’re referring to. If you have doubts just remove the line at the carb and kick it over, fuel should come out. Make sure that both fuel valves are open before you give up on the pump.
    Then remove your reed cage, clean it up real good and push the rubber manifold into your face, block the boost bottle hole with your finger and suck. If you face doesn’t pucker up like your sucking on a bottle it means your reeds are leaking and need to be replaced.
    With the cage off, rotate the engine a couple times and then run the piston up to TDC, take a flashlight and look inside the case to see if you can see fuel and oil running off the crank and rod. You MIGHT have it till of fuel which would explain why it will start after sitting and evaporating for a day.
    This is a bit of a reach, but it can happen. The cause is either a leaking float needle, or bad fuel. You would have to soak it out with rags, or remove the engine and dump it and then fix your fuel system before trying to start it again.
    No matter what you find you still need to check for leaks as was recommended by others. That’s a must on every 2 stroke rebuild.
    Regarding your compression reading, do you know how to do a proper one? Carb wide open and kick it over till the gauge stops going up, takes at least half a dozen kicks of not a dozen. You can find it on YouTube.
    Last edited by El Camexican; 01-01-2018 at 12:20 PM. Reason: Because pizza is round and comes in square boxes cut into triangles
    It sucks to get old
    Jun 2015
    stonecreek ohio usa
    654
    Racer x believe it or not I was getting a blue spark but it must have been very intermittent. That's the only thing we could figure.
    Jul 2013
    USA
    737
    Got the plug picture?
    Jun 2015
    stonecreek ohio usa
    654
    I don't. That's been awhile
    Jul 2013
    USA
    737
    I hate to say it but I may have to bite the bullet and take this machine to the shop and pay (money that I don't have) for them to figure it out. I don't understand why it starts for a minute or two but only if its cold and its the very 1st attempt at starting it for the day. It starts right up but runs sorta boggy (if I give it throttle it wont rev up high at all and instead it boggs down) and I have to blip the throttle a little bit just to keep it idleling but it eventually gets slower and slower and boggs out completely. Then after that it wont start again? Not even with a shot of starting fluid even though it was just running for a minute. But it will start tomorrow and do the same thing. It will run like crap for a minute, just Bogg out, and wont start again? I bought it a few years ago, put plenty of miles on it, and it ran ok. It just smoked more than its supposed to which I assumed was due to an old worn out piston and jug. Then it started doing what's its doing now. I figured it needed rebuilt or reeds or something. so now I finally got it all back together after having it bored .040 over. (fyi don't bore a tri z jug to .030 because for some reason nobody makes rings that size? You can get .010, .020, and .040 only) Its got a new air filter, carb is squeaky clean, new reeds, new piston and rings, plug, ect.... The compression gauge is reading 155psi. the spark plug is definetly sparking. I even tried another plug just in case and they both spark fine. So it seems I have fuel, air, and spark but its not running? I thought maybe the stator but its sparking fine. And I also thought maybe the fuel pump but why would it not start with a shot of starting fluid and why does it pump fuel for a minute or 2 and then stop? With starting fluid sprayed in the cylinder it should at least run for one second or 2 even if the carburetor was completely missing and it literally had no fuel in the tank right? It doesn't even try to start. It doesn't even hiccup? Once it runs for a minute and boggs out its done for the day. I could kick it 100 times and absolutely nothing happens? Maybe I'll try gravity feeding the carb and eliminate the possible faulty fuel pump completely. But the possible bad fuel pump doesn't explain why it doesn't show any signs of life with a shot of gogo juice.
    I just don't get it?
    Any thoughts?
    Attachment 248911
    Attachment 248912
    Is it possible to see a picture of the spark plug. The one that was in it when it quit running?
