Results 1 to 15 of 15
Thread: Cheap beater fender fix
    Sep 2017
    Cadogan AB Canada
    52
    I had an oops with my old big red and broke and already rigged together fender totally in half and can't fix it good this time. Do you guys have any good cheap ways for getting a fender back, I don't want to buy new and I know of buying used obviously, im more looking for hacks or ways of making new fenders with materials you have laying around ??
    Jun 2009
    Leander TX
    2,217
    Zip tie stitching.
    Connecticut
    1,605
    Quote Originally Posted by 85bigred00 View Post
    Sheet tin and pop rivets can hold a fenders shape when they are really busted up or broke in half
    Aug 2015
    H B
    103
    Fiberglass
    Sent from my iPhone using Tapatalk Pro
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    420
    I use either zipties or sheet metal and pop rivets. Them I cover it with zip tape which is very strong. It is used to bridge the gap of OSB sheeting on new construction homes.
    Willamstown PA
    5,822
    ty wraps, drill a small hole at the end of the crack. it will never crack again then black or white white tire it together tightly. you do not need to X them. rivets don't allow the fender to bend and just break again..plus rivets are for boats.
    Sep 2017
    Cadogan AB Canada
    52
    ok so ive done all these things kind of on the other side and this side was already bent up. So I guess I might try some zip tie stitching because it has been snapped in half twice now and I already have a bunch of sheet metal with pop rivets lmao.
    HondaRidr's Avatar
    Salt Lake
    343
    DON'T USE ZIP TIES PLEASE! Buy a cheap spool of 40 or 50lb fishing line, use a very small drill bit and drill holes (about 1cm away from the crack) along both sides of the crack, stitch the crack with a crisscross pattern. Time consuming but is very strong and a million times better than zipties. I even have some red and green line to match Honda or Kawasaki fenders.
    Sent from my SM-G930T using Tapatalk
    Sep 2017
    Cadogan AB Canada
    52
    Well since its totally broken in half I might just try use the metal and rivets again because the fenders are totally destroyed by this point so idc anymore I just wanna beat my trike. I will get a nice one later in life.
    plevib's Avatar
    plevib is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Dec 2015
    North Dakota, USA
    358
    Quote Originally Posted by HondaRidr View Post
    Haha sounds like way too much effort. Zip ties for me.... even on my subaru because rally car
    Sent from my SM-G900V using Tapatalk
    Atc 500x for the win! (Hopefully.... one day)
    Oct 2011
    Lebanon, Oregon
    132
    Have done the Zip Ties they work pretty good...
    MF!
    oldoo's Avatar
    oldoo is offline At The Back Of The Pack Arm chair racerFirst time rider
    May 2017
    Australia
    155
    If you have a heat gun, you can plastic weld it with a strip of plastic used as a filler wire. I repaired the fender shown from the underside so it looks clean. But you can plastic weld from both sides for the best penetration for maximum hold/strength.
    Oct 2011
    Lebanon, Oregon
    132
    I need to buy a heat gun...what would be the best one to get?
    MF!
    Sep 2017
    Cadogan AB Canada
    52
    Got the ol fender finally back on. good ol sheet metal and rivets along with a few integral zip ties.Click image for larger version.
ID:	252177Click image for larger version.
ID:	252178Click image for larger version.
ID:	252179Click image for larger version.
ID:	252180Click image for larger version.
ID:	252181Click image for larger version.
    Oct 2011
    Lebanon, Oregon
    132
    That’s Cool ��
    MF!
