Need help identifying the rod in my helm atc 110 stroker. It looks like a 26mm crank pin with a 15mm gudgeon. The markings are i think s9 943.
Cheers Will
Cheers Will
What are you needing to know. Where to find a new rod?
* Nicholson 500 Race Bike *
you wont find one that has been SQUASHED, that is a lost form now
The early points 110 had a 26mm pin. Same centre to centre length as the 30mm version.
Most strokers used a "stock" rod that was modified as Kasey mentioned. You should be able to find one fairly easy and cheap on ebay.
Looks to be a standard H&S 58mm stroked crank with squashed rod which eliminated the need for cyclinder stroker plate. Early strokers used stock rod lengths and stroker plates, longer cam chains and a couple other modifications. When you do build it, post up a thread with pic's we all love to see custom projects.
"HJ"![]()
’84 YT60
’89 TRX250R (stock )
’90 LT500 Quadzilla
Gday
I built this motor a couple years ago. I used the above crank and atc125m barrel decked down 6.3mm and 57mm gy6 piston.
http://www.3wheelerworld.com/showthr...with-ATC-parts
Looks like the pics are gone.
