Results 1 to 3 of 3
Thread: 1983 200 worn rear brake drum: will other models fit?
    Dec 2015
    Port Robinson
    7
    I have a 1983 200 honda with worn out rear drum . Will others fit ?What about atc 125 drum ? I really don't need rear brakes , but just want everything working as it should .
    Would like to know what others might fit before searching ebay .
    Thanks for any help
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    A 125m brake drum should fit, they use the same brake pads. But for sure 185, 185s, 200s, 200m, and 200e will work.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Jan 2018
    Michigan
    18
    Quote Originally Posted by Tim Hall View Post
    Thanks for any help
    I've noticed in my very brief search for various parts that if you Google the Honda part number for the part you want, it'll frequently identify other Hondas that use the same part.
