Results 1 to 15 of 17
Thread: Splitting case !
    Oct 2017
    Liberty,Nc
    83
    Splitting case !
    So I know most of you probably will say get a splitting tool but I’d rather not spend 50+ when the repair Manual tells me to do this . Click image for larger version.
    Anyone got any tips doing it the above way . I’m replacing all trans and crank bearings / seals so hopefully I won’t have to crack her open for another 30 years
    Mexico
    9,020
    What engine?
    It sucks to get old
    Oct 2017
    Liberty,Nc
    83
    1985 atc 125m
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by mr-bubble66 View Post
    1985 atc 125m
    Just do it the way it says.. the key is not to use a pry bar in between the halves.. it should come apart fairly easy with a rubber mallet or dead blow.
    Sent from my XT1650 using Tapatalk
    1974 original 90 X 2
    1974 Original 70.
    Arizona
    843
    Some cranks are press fit so you have to use a case splitter, otherwise you risk doing more damage than the tool costs. I'm not sure about your 125.
    125Mmadness's Avatar
    125Mmadness is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2017
    McConnelsville,Oh
    157
    125M cranks aren't press fit, rubber mallet works just fine.
    1985 ATC125M: Parts
    1985 ATC200S: 84 200S Bottem end, 200x Head, 200x Carb, S&S Cycle Exhaust, Wiseco 10.25:1 Piston, Reground Cam with About 1mm more lift(unknown specs).
    1988 TRX250X
    1983 ATC200E: Total Pile.
    "Bout Tree Fiddy" Master of Thy 22RE
    Gripit'n'ripit's Avatar
    Gripit'n'ripit is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    Rochester NY
    251
    I've split a few 125's. clean the outside of the halves on the seam well. get the debris off with a wire brush or rag.
    Take your time, be patient. Just keep working around with the rubber or plastic mallet. If you do not have one, use a piece or wood or another softer medium to place against the case and strike.
    be patient and just keep working around. I've had cases split beautifully in a few cracks, and some seemed like they would never split (until they did)
    haven't damaged one yet.
    penetrating fluid around the bolt holes and stud points.
    Did I mention, be patient.
    81 250R Custom
    83 250R (in progress)
    98 Scrambler 400
    03 Bombardier Quest 500
    07 Polaris Predator (sold to klondike1020 )
    68 VW Dune Buggy
    Nov 2015
    Davenport iowa
    1,144
    Thumbs up
    Quote Originally Posted by Gripit'n'ripit View Post
    Oops wrong thumb, I liked this post..
    Oct 2017
    Liberty,Nc
    83
    Alright thanks for the tips! I’ll attempt at it one day this week
    Mexico
    9,020
    Quote Originally Posted by DAM shop View Post
    Just click "dislike" again and it goes away.
    It sucks to get old
    Mar 2008
    Tug Hill
    1,282
    do you happen to have one of those duck foot steering wheel covers or a universal puller? some cases can be split using one of these by putting the center of the puller on the crank shaft and bolting the outer holes of the puller to the case. tapping around the case with a rubber mallet as you tighten it.
    Mar 2008
    Tug Hill
    1,282
    Not sure off hand if you can do this with the 125 or if you have a puller but figured id post it in case.Click image for larger version.
    Nov 2007
    Rochester NY
    251
    I HAVE gone that route before ^^^^^^^^^^^
    I've even made a case splitting tool with heavy flat stock and bolts. they may have worked, but always gave me more anxiety in the process.
    The cases are designed to fit tightly and snugly, and any forces you apply that might go beyond those descriptions always make me nervous.
    As long as you don't take a torch too it though.........
    DAM Shop -It's okay, I've gotten a lot worse than just a thumbs down before LOL.
    81 250R Custom
    98 Scrambler 400
    68 VW Dune Buggy
    Oct 2017
    Liberty,Nc
    83
    No I don’t have any pullers haha also when I get case apart would it be okay to wash trans gears and crank with kerosene
    Mar 2008
    Tug Hill
    1,282
    ya I think kerosene is a good option its cleans and unlike some solvents will leave a bit of a film to protect from corrosion. just wear gloves and dispose of it properly
