Thread: Time Sert by Wurth thread repair
    May 2016
    OH Canada
    1,102
    I did a search and did not come up with anything. I have used this in the past and works great. I have done some helicoil but the time sert takes the cake. I was talking with a local rep about this the other day. I have used Wurth stuff for over 30 years.
    Thread Repair | Time Sert
    Time Sert
    The best thread repair system on the market! Solid steel, copper or stainless steel bushings allow permanent thread repair in most any surface with 4 easy steps.
    1. Drill out old threads.
    2. Counter bore hole.
    3. Use Time-Sert tap to re-tap hole
    4. Insert bushing into hole with Time-Sert Insertion tool.
    The TIME-SERTŪ system is based on a solid steel bushing machined from a solid piece of material. The thin-walled bushing is press-fitted to the workpiece. Therefore, TIME-SERTŪ is able to withstand high continuous strains as well as frequent tightening and loosening of screws. The available bushings can be used with ISO, coarse-pitch, fine-pitch and unified threads.
    TIME-SERTŪ can be used in aluminum, brass, steel or casting materials.
    '83 200X
    AMK's Avatar
    AMK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2017
    Shelby, OH
    181
    Your link threw me an error.
    Alan
    1985 350x
    1984 200es Big Red
    1985 200s (little red)
    1986 200x saga
    2) 1985 350x projects
    And a slew of others to hold my attention
    May 2016
    OH Canada
    1,102
    Quote Originally Posted by AMK View Post
    Sorry about that. Link worked in my preview. After posting I got the error too. Vids from Youtube blow. I will try and link a better one.
    http://www.wurthusa.com/web/en/websi.../time_sert.php
    '83 200X
    AMK's Avatar
    Jul 2017
    Shelby, OH
    181
    Yep, that worked.
    Alan
    1985 350x
    1984 200es Big Red
    1986 200x saga
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    Hey Rob,
    Do you know if this would work for a recessed hole? Such as a hole where a dowel pin goes, so the threads are @ 5/16" below the case surface?
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
