Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 37
Thread: 200x Petcock question
    Feb 2018
    Yuma
    27
    Hello Everyone, glad to be a member of the forums....I have a quick question, is the petcock on a 1985 Honda 200x a vacuum petcock? I was having trouble with fuel delivery, I got the bike started and it idles now and runs however as I was going through the process of trying to figure out what was going on I pulled the hose from the petcock and turned the petcock to on...The gas didn't flow out like a steady stream, it was flowing but more dripping than anything....I asked a friend of mine and he said it might be a vacuum petcock which means the engine has to be running for it to flow like I was expecting. Thank you in advance for any help with this issue.
    6,802
    It’s just a regular gravity feed petcock . Time for a new one .
    Aug 2015
    Idaho
    838
    What does the inside of the tank look like? Could there be a blockage? How does it run when you gas it?
    Feb 2018
    Yuma
    27
    Yep I was afraid of that, really wanted to ride it today too, I found one on ebay for 7.99 I'll order that one tomorrow...Thank you/
    The tank was cleaned out and flushed before I bought it, however I was told the tank had rusted through at one post and was welded....It responds well when I gas it, Sometimes when I ride it though it likes to shut off and not fire up after...Usually it starts on first kick. I'll make a video of all that is going on. Thank you both for your response.
    May 2016
    OH Canada
    1,102
    Quote Originally Posted by Scorpion200x View Post
    The second part looks like the same issue. Running out of fuel. You are using more fuel than the petcock will allow back to the carb.
    '83 200X
    Feb 2018
    Yuma
    27
    It seems that way, I really do thank you guys for your help, I have been coming here reading the forums a lot and finally decided to join. Here is a video of that it is doing. I will order one tomorrow regardless.
    May 2016
    OH Canada
    1,102
    Just for fun. Remove the gas cap and see if it flows.
    '83 200X
    Feb 2018
    Yuma
    27
    Quote Originally Posted by Rob Canadian View Post
    Nope, it stayed the same.
    May 2016
    OH Canada
    1,102
    Ok. It was just a simple test that may have got overlooked. Thanks for posting up a vid.
    Take the old petcock off. See if you can clean it(?) before ordering a new one.
    '83 200X
    Feb 2018
    Yuma
    27
    I did what you said and this is the result....Thanks so much for all your guys help and quick response...Now I need to put the bolts back on the tank and the seat back on and go rip some of this desert sand.
    May 2016
    OH Canada
    1,102
    Great to hear. Now go have a blast!!!!!
    '83 200X
    6,802
    If the factory petcock filter is damaged or gone make sure you put an inline fuel filter on your fuel hose so you don’t get crud in the carburetor .
    May 2016
    OH Canada
    1,102
    Is this the fuel strainer? Looks like it goes around the inlet to the petcock. I have honestly never had mine out. Both my trike and bike have rust free tanks so I have never looked into it. I know my bike has a removable bowl off the petcock. Which I have removed and cleaned...
    '83 200X
    Aug 2015
    Idaho
    838
    It's hard to see the position of the petcock in your first vid, but at 15 sec it appears to not be in the on position. Second vid clearly shows in 'on'.
    Rob- the strainer should be right behind the valve, I think. It is on our 70.
    I
    Feb 2018
    Yuma
    27
    I know the 2nd time in the first vid I did not turn it all the way. I noticed that. However the first time I turned it to the on position in the first fist vid It was on just out of camera vision. Now I have run into another problem, i went riding today and all was well. When i came back home it shut off I thought no biggie I'm home. I then notice gas pouring from the over flow hose. I turned the petcock to the off position, I tapped the carb with the handle of a screw driver thinking the float is stuck that didn't work. So I took it apart cleaned it when carb cleaner, removed the float and cleaned it as well however the problem is still ongoing...any ideas....I also want to note this trike was sitting for a while before I bought it from the guy.
