Page 3 of 3 FirstFirst 1 2 3
Results 31 to 37 of 37
Thread: 200x Petcock question
  1. #31
    It's very likely you're not threading the needle into the main jet and that's holding the slide open. As Rob said, disassemble and make sure the slide is closing all the way, and as Shep said, always lift the slide up off the adjustment screw when adjusting the idle.
    May 2016
    OH Canada
    1,102
    If you now have more free play in the throttle than you did before, then something isn't allowing everything to go back to the idle position. Maybe your needle didn't quite go back into the hole that it rests in?
    "That's what she said"... OK. I had to make a funny...
    '83 200X
  3. #33
    Feb 2018
    Yuma
    27
    Quote Originally Posted by Rob Canadian View Post
    I got it sorted. I guess I did have the slide in backwards. Runs smooth now have the inline filter on it as well. Thanks guys
  4. #34
    May 2016
    OH Canada
    1,102
    Quote Originally Posted by Scorpion200x View Post
    Glad to hear!!!
    I was sleeping. Different time zone.
    '83 200X
  5. #35
    Feb 2018
    Yuma
    27
    Glad to hear!!!
    No worries you guys have been a real big help, I greatly appreciate it.
  6. #36
    Aug 2010
    Scranton,SC,USA
    I have a 1985 Honda Big Red 250es. I just recently replaced the fuel petcock. I can't get fuel to flow out of it once i hook it to the carb. When i unhook the fuel line from the petcock to the carb it flows fine. As soon as i hook it back up to the carb it stops. I have an aftermarket plastic tank as well. Any suggestions
  7. #37
    6,811
    Your float valve is probably stuck closed in your carburetor or maybe the bowl is just full or fuel . Open the drain screw on the bowl and see if the fuel will start flowing .
