What kind of paint stripper do you guys use on plastics i'm trying to un-camo my yamaha. I see air craft stripper recommended any particular kind ? What have you used and where can I get some ?![]()
No trike left behind
1983 Ytm 200
1983 Honda 200
1982 Honda 185s
1983 odyssey fl 250
1987 yz 250
Your local auto parts stores will sell the aircraft paint stripper in a spray can or brush on type. I’d say buy 3 or 4 cans to start with. I’ve tried several different brands, they seem to work ok but also run out much sooner than expected.
The last few times I used it everything involved was pretty cold, that may affect the stripping?
If you have any brake cleaner it will strip paint. You should spread out paper towels on the fenders and let them soak it up to keep from dripping off.
Brake clean will do it without messin up the plastic ?
1983 Ytm 200
1983 Honda 200
1982 Honda 185s
1983 odyssey fl 250
1987 yz 250
I use Rust-Oleum brand aircraft stripper from Walmart. Brake cleaner doesn't work well and evaporates too quick in my experience.
Sent from my XT1254 using Tapatalk
Thanks, i'll give it a try.
1983 Ytm 200
1983 Honda 200
1982 Honda 185s
1983 odyssey fl 250
1987 yz 250
I hijacked your other thread with that question. The answer was aerosol aircraft stripper and another seconded it so I got some at AutoZone and tried it under the fender and they were right.
It worked great.
Alan
1985 350x
1984 200es Big Red
1985 200s (little red)
1986 200x saga
2) 1985 350x projects
And a slew of others to hold my attention
It's all good man, I just wanted to know if any body had experience with any particular brand or kind so I don't melt my fender. It's all about helpin out each other.I read a couple reviews about the autozone stuff and they weren't good. So I just wanted to see what was what before i did anything.
1983 Ytm 200
1983 Honda 200
1982 Honda 185s
1983 odyssey fl 250
1987 yz 250
homedepot product called kleen strip...then brake fluid and low abrasive steel whool bath...make crap look good. See attached.
Damn, That crap do look good !![]()
1983 Ytm 200
1983 Honda 200
1982 Honda 185s
1983 odyssey fl 250
1987 yz 250
I have used the kleen strip several times as well and it works great!
