Results 1 to 15 of 20
Thread: Homemade trike trailer
    Sep 2017
    Cadogan AB Canada
    52
    So where do all you guys stand on homemade trailers to pull behind your trikes? I have a beat up old bigred so I figure I might as well put it to work and build it a trailer, I still need to do some research but I am in shop in school this year and could get a credit for building it so I figure might as well. How many of you guys have built your own trailers and what do you find works the best? Like does it needs springs and what kind of tires are best? Any input is great, I will make sure to put of pictures as I get an idea and start to build.
    Jun 2013
    Oceanside, CA.
    614
    Size and shape all depends on your use. I made one out of box tubing, plywood, sheet aluminum and aftermarket front 3 bolt ATC hubs. When built in '82 used by ATC110 to pull it. Carried ice chest and firewood to Comp Hill. Still have it and is used to collect firewood while at the desert. All my desert toys are set up so they can pull it. Would make it bigger if making it again.
ID:	250068 Click image for larger version.
ID:	250069 Click image for larger version.
ID:	250070 Click image for larger version.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    ky
    88
    Could you tell us more about the xr650 250r?
    Sep 2017
    Cadogan AB Canada
    52
    Well i want a true workhorse trailer i think. The 250es is fun to brap but it will be better for work horsing than my crappy Polaris quad that i have, I have looked at some pictures and seen the 4 wheel cantilever suspension. I will probably be hauling loads of wood out of the bush and carrying tools and maybe even dirt. I guess i shouldn't make it too big or else I will overload the old girl.
    Jul 2012
    Seattle, Washington
    1,543
    I missed out on buying this one for $40.00 on offer up. I want one for camping & taking the kids for a ride. This year I’m gonna let them start riding by themselves, but trailers are still cool.
ID:	250089Click image for larger version.
ID:	250090Click image for larger version.
    Aug 2015
    Idaho
    849
    Good for you!! There's a member here just wondering if there are shop classes still available. Can't wait to see what you build. I'm into little trailers. Our big red pulls 4 trailers around here. I've got one torn down and half of it is sand blasted. I can't say I've built any of them. Sounds like a great idea if you can use it (or not)
    Jun 2013
    Oceanside, CA.
    614
    Here are several other ideas and or options.
ID:	250095 Click image for larger version.
Name:	Dump Cart_01.jpg
ID:	250096 Click image for larger version.
Name:	hondaline - dico trailer_05.JPG
ID:	250097 Click image for larger version.
Name:	hondaline trailer_11.JPG
ID:	250098 Click image for larger version.
Name:	misc trailer_01.jpg
ID:	250099 Click image for larger version.
Name:	Rocket Trailer daggett43_01.jpg
ID:	250100 Click image for larger version.
Name:	Sears Craftsman Trailer_02.jpg
    BarnBoy is offline Just Too Addicted Arm chair racerJust too addicted
    Jun 2015
    Oklahoma
    732
    Bush Buggy trailers are awesome. Light and super tough. Also expensive though. But we have hauled almost anything imaginable with them....from welders, to firewood, garbage, people (grandkids), rocks, dirt, you name it.
    1981 HONDA ATC185S - parts
    Da velder
    Feedback:
    Sep 2017
    Cadogan AB Canada
    52
    Ok thanks for the input guys. So big reds can haul pretty good loads but this trailer might get pulled other atvs in the future idk for sure. It looks like most trailers are pretty small with only 2 wheels. What do you guys do for suspension if any, like we talking some little leaf springs or like a small version of walking beam suspension because I kinda want to overdo it just for shop so i can get a few credits.
    Aug 2015
    Idaho
    849
    Quote Originally Posted by 85bigred00 View Post
    Ok, now the walking beam suspension sounds great! It's challenging, to say the least, turning or side-hilling with a bunch of tongue weight. I was thinking 4 wheeler would be real nice, if it could maintain a lower center of gravity, depends on terrain and intended use I guess. I really like a low slung flat bed for moving all kinds of heavy items.
    I think you're headed the right direction [emoji106]
    Sep 2017
    Cadogan AB Canada
    52
    I need it to be a little challenging because its a higher level credit so I need to do some engineering to make it worth while. Mine will most likely be used to haul wood out of tight areas and maybe haul salt and stuff out to the cows in the field. I just need to find a place to buy small trailer hubs so i dont go crazy over budget but I dont want those crappy garden trailer tires.
    Michigan
    1,144
    I made one for using around the yard and going in the woods to haul firewood. I suggest that if you are going to do much in the woods. make the width the same as the big red or what ever your tow vehicle is. If the tow vehicle can go between two trees so can the trailer.
    85 Big Red
    83 Big Red
    84 125m
    85 TRX 125
    73 ATC 70
    kevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2011
    Manitoba
    172
    I made a pretty nice one I'll see if I can find some pics but I had an old rotted small tow behind car trailer that I used the torsion axles and build my new trailer to the lengh and width dimensions the same size as the fiberglass top. Made up 2" wheel spacers so I can run atv tires also lifted the frame an extra 8" so I could tuck tires under the frame and not hang out at all also wanted a complete flat bottom tilting trailer. Sides are made of stainless steel and bottom uses coragated aluminum floor basically same pattern like in a truck box. Also tailgate is on hinges.
    Has lots of ground clearance and is no wider than my quad I use to pull it with. Use it to haul wood, sand, coolers with our favourite beverages and more
    Mar 2011
    Manitoba
    172
ID:	250142 found a couple pics
    Attached Thumbnails Attached Thumbnails 20150510_204801.jpg   20150510_204156.jpg   20150510_204138.jpg
    Mar 2011
    Manitoba
    172
    Still can't figure out why some pics are upside down
