Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: 250 biig red to 300 engine swap
    fingerlakesny
    2,834
    Thinking about doing a swap. What are the advantages of the 300 engine ? Also what needs to be changed or swapped ?
    250r dust runner
    fingerlakesny
    2,834
    Guess I wont be building one of these...jeez , whats happened to this site...
    250r dust runner
    May 2016
    OH Canada
    1,102
    Quote Originally Posted by dustrunner View Post
    IMO. More info is needed. You are not giving much info to go on.
    '83 200X
    Go build your bike or don't, we ain't gonna do it for you hunny.
    If memory serves me, there's been at least one thread on this and it's not a direct bolt in. Try searching the forum first. I could find the thread for you but I'm not going to. I'd just be guessing but the 300 is likely no more than 5 hp over the 250. Now go get yourself a tissue.
    Footy's Avatar
    Feb 2015
    Charlotte, N.C.
    437
    There is not much HP increase. I do know that the regulator rectifier and a few other electrical components are different. I suppose if you had a wrecked 300 and all of the parts were on it you could make it work with enough time. My experience has seen that the rear end gears will fail before the engines on either the 250 or 300. I would say that is why this has not been done much. I have seen the rear end components swapped out between the 2.
    TRX450ER
    ATC250SX
    ATC350X
    ATC250ES
    ATC110
    ATC185S (Marlboro Red)
    XR100R
    CRF230F
    Raptor 125
    Breeze 125
    Grizzly700
    kevin is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2011
    Manitoba
    172
    Angle drive has to be changed over aswell
    fingerlakesny
    2,834
    Didn't your momma tell you ( If you don't have something nice to say , don't say anything at all ) No tissue needed, what a jerk. !
    250r dust runner
    Apr 2014
    Edmond, KS
    2,591
    No idea how much, but I'd think that you would get a decent gain in torque too.
    glendive, montana
    1,822
    do you already have a 300 motor to start the build? I have one sitting needs timing chain and a flywheel as the type honda used in that motor eventually die from the heat of the oil
    Connecticut
    1,605
    Does facebook give you instant gratification? Jeez what happened to letting a thread simmer a couple days before dissing a free resource with stuff you could look up yourself before even commenting....you just asked and got frustrated after a day of no replies....Maybe the seller of this kit will chime in
    fingerlakesny
    2,834
    No , I have nothing . was thiking about building one but with minimal benefit's I will build something worth value.
    250r dust runner
    fingerlakesny
    2,834
    Quote Originally Posted by sledcrazyinCT View Post
    Just seem's ( to me ) thing's are pretty slow around here... And I asked a question about a build , that if I had done I would love to share the highs and lows with members thinking about a similar build. Seems like a certain few are waiting to Pounce on fellow " brothers " ...
    250r dust runner
    Things are slow because internet forums are a dying platform, not because of the people who frequent this place as guys like you and Mosh like to infer. You asked a question without even searching first, then you you dumped on us because we didn't search for you, something you should have done on your own right off the bat. You don't like the forum? Don't use it, but you're not going to come on here and put us down for not doing your homework for you.
    Mar 2017
    New Jersey
    89
    I thought that this place was for help? Don’t feel bad dustrunner I ask questions all the time and get nothing it’s a good thing I do t have to pay a monthly due like other forums or I would won’t a refund
    Nobody's forcing anyone to be on this forum. If you think nobody helps anyone on here your perspective might be a bit off.
