Results 1 to 15 of 22
Thread: ATC hard start when warm
    Oct 2017
    Hutto, TX
    75
    One of my 70’s start first or second pull every since I got it. The problem is after I’ve ran it for ten minutes or so (approx...may be less) it will either stop or if I turn it off, then it becomes hard to start. I’m thinking it may be a fuel problem. It has new fuel lines, tank is clean, carb is clean. I’m going to change fuel filter and open to suggestions.
    May 2016
    OH Canada
    1,102
    I am kinda thinking maybe the gas cap is not venting properly.
    '83 200X
    Oct 2017
    Hutto, TX
    75
    Interesting. I’ll swap out the cap and try that.
    Very likely the valves need to be adjusted.
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by Rob Canadian View Post
    We've had this happen. How's your plug look after those 10 minutes?
    Oct 2017
    Hutto, TX
    75
    I haven’t checked the plug, I’m out of town right now, but what should I look for? What happened to yours?
    Cold Lake, Alberta, Canada
    3,019
    Ding, ding, ding for Fabio! Valves are probably set too tight making you lose compression as the metal expands.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Nov 2015
    Davenport iowa
    1,144
    Quote Originally Posted by spacerust View Post
    A vapor lock on your gas cap won't allow fuel to flow, usually happens after a short time of riding and she'll just stall out..
    Your plug should be light tan, you don't want white or black and oily or sooty, light tan in color is a good burning plug. But you should also check your valves like the others said.
    Oct 2017
    Hutto, TX
    75
    I’m heading back home later this afternoon. If the plug is black or other, what should I check?
    Honestly I'd skip the plug and just adjust the valves. It's very easy to do and your most likely problem. It would be the first logical step.
    Oct 2017
    Hutto, TX
    75
    Okay. I don’t have my manual on me, but just to keep my mind busy on the drive, it’s .005 on the intake and outtake right? If I remember correctly.
    Nov 2015
    Davenport iowa
    1,144
    05mm or .002in on the valve tappet clearance.
    Sent from my XT1650 using Tapatalk
    1974 original 90 X 2
    1974 Original 70.
    Jul 2013
    USA
    737
    Do you have a factory air filter on this trike? Do these 70's use traditional points and condenser? I suspect some overheating, valves do seem probable. Did it ever restart good? We want some plug pictures too!
    Quote Originally Posted by fieldy View Post
    He didn't say anything about overheating, I don't know why you would suggest that. Every laydown engine I've had has done this at one time or another. It's a routine adjustment to account for normal wear and tear.
    Jul 2013
    USA
    737
    I have had trouble restarting 4 stroke motors that i know were slightly overheated. Thats why i said that.
