Hey guys! Just been working on my 85 250R and got my cylinder honed by a buddies shop. There is still some very light scratches up and down. should I be worried?
Thanks
Thanks
Tough to say from just that picture but as long as it measures within spec you should be OK.
If you can feel the groves with your fingernail then it’s going to loose compression but I would run it break it in and do a compression test and make sure it’s with in specs .
I'd be more concerned about the ridge at the top.
Alan
1985 350x
1984 200es Big Red
1985 200s (little red)
1986 200x saga
2) 1985 350x projects
And a slew of others to hold my attention
Do those scratches line up with the ring gap ?. If so the end of the rings need to be lightly smoothed over.
YAMAHA 450 HYBRID
85 350X- RED
85 350x -BLACK
86 350x-WHITE (with Goki)
85 250r
83 atc 70
84 atc 70
84 atc 110
09 yfz 450
2006 Arctic Cat Prowler
RZR XP 900
