Thread: Small scratches
    Mar 2015
    Manitoba
    98
    Small scratches
    Hey guys! Just been working on my 85 250R and got my cylinder honed by a buddies shop. There is still some very light scratches up and down. should I be worried?
    Thanks
    Tough to say from just that picture but as long as it measures within spec you should be OK.
    6,801
    If you can feel the groves with your fingernail then it’s going to loose compression but I would run it break it in and do a compression test and make sure it’s with in specs .
    AMK's Avatar
    AMK is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2017
    Shelby, OH
    181
    I'd be more concerned about the ridge at the top.
    Alan
    1985 350x
    1984 200es Big Red
    1985 200s (little red)
    1986 200x saga
    2) 1985 350x projects
    And a slew of others to hold my attention
    devore,ca
    1,017
    Do those scratches line up with the ring gap ?. If so the end of the rings need to be lightly smoothed over.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
