Results 1 to 15 of 17
Thread: Clutch Issue, 85 200x.
    Feb 2018
    Yuma
    27
    Okay so I posted before about my trike having all the carbon build up and all, the guy I bought it from is also the mechanic that stripped down the motor and saw how bad it was, Remember he bought it a year ago and then sold it to me without riding it much. Anyway he gave me his other 200x engine until my top end gets rebuilt (which was awesome) However I am noticing with this engine my clutch seems to only work when the trike is warmed up. For example, If I start the trike up and try to shift into first with the clutch pulled all the way it will just jump forward and shut off. If the trike is off and cold and I pull on the clutch and put it in gear I can't push it forward or backwards the back tires will just lock up as if the clutch isn't being used....Only when the trike warmed up will the clutch begin to work and work well, I don't have any problems with it after that....Any Ideas Wth is going on here, or is this just a common thing with these machines....Mind you this is the first trike I have ever owned I was more of a dirt bike rider...thanks in advance guys.
    6,818
    Could be a worn clutch basket but it is common for the Honda clutches to be stuck when cold .
    A couple oil changes with some gn4 might help as well .
    Feb 2018
    Yuma
    27
    Forgot to update this with the results....It's working now as it should just have to warm it up a little before taking off
    May 2015
    San Diego, CA
    1,800
    Quote Originally Posted by Scorpion200x View Post
    I'm glad it's working for you but........
    I still would be tempted to inspect the basket and more over........clean thoroughly the drive and driven plates.
    Apr 2012
    USA
    4,129
    Do you know how long the engine sat? Might just be some buildup on the clutches. I've bought a bunch of ratted out "junk" 3 wheelers that sat for years. Got them running and right away the clutches didn't work very well. After a couple hours of riding and shifting a lot, they generally end up working like normal. If it sat for a long time, I'd suggest changing the oil if you haven't already. Just make sure the oil has the right specs for wet clutches. Any oil that claims better mpg or low friction will have friction modifiers in them which won't work with the clutch.
    Mar 2017
    Elkton, MI
    5
    I’m installing the clutch basket right now and using the special tool to tighten it the basket itself spins, so where the book says to use the penny isn’t doing me any good. I’ve never had this happen before and I’m stumped
    Jul 2018
    TN
    1,065
    Clean the oil centrifuge while you’re in there.
    The last set of clutches I put in I used an impact and held it with a welding glove
    Slidell, LA
    4,738
    Quote Originally Posted by Slappy View Post
    If you don’t have a clutch holding tool, they are unobtanium, then tighten the nut down with a couple wraps of an impact.
    Mar 2017
    Elkton, MI
    5
    I can spin the plates and the 4 posts when I turn the special nut. Is that normal?
    Slidell, LA
    4,738
    Yes, that is normal on a 200x.
    Apr 2012
    USA
    4,129
    I normally stick a flat head screw driver in the gear teeth to stop it from spinning. Not the most ideal thing in the world, but another option. Idea is to get as much of the tool to contact the screwdriver as possible to spread out the forces more. I think that would be easier to work with than a penny, penny is probably suggested because it's made of copper (1982 and older) and is weak enough not to damage the teeth.
    Slidell, LA
    4,738
    You cannot “gear lock” the inner clutch hub on the 200x. Rather if you are talking about how to lock gears then I would use a penny or get a motion pro gear locker off of Amazon.
    Mar 2017
    Elkton, MI
    5
    But I can’t use the gears to stop the basket from spinning at this time. Click image for larger version.
ID:	255726this deal will spin when I try to tight it. Click image for larger version.
    Apr 2012
    USA
    4,129
    Interesting, never had to pull the clutch basket on a 200x, so never really messed around with that model that far. Worked well for a 250es, that or I put it in a the highest gear and stopped the tires from moving. I see the engine is apart a lot, I've always had the engine in the machine when working in that area, so little different situation. If you can stop the output shaft of the transmission somehow, could put it in the highest gear and try that, have to hold the engine somehow too. The proper tool would probably be best lol. AKA, flat bar/sheet, drill the bolt hole locations out and mount it up to the 4 bolt holes and have the center cut out for the socket and a long enough handle to stop it from spinning..
    Slidell, LA
    4,738
    I assume you are right handed? If so put a thick glove on your left hand or get a bunch of rags to hold the inner hub. Then hit it a couple times with your impact. Make sense? You are holding it while you drive on the nut with an impact.
