High comp 200x piston..
I decided to rebuild my 1985 Honda 200x auto s engine, because it seems to be loosing power and smoking. I have a brand new in the box Weisco high compression piston, with a bunch of extra parts (few cylinders too). I will be installing the high comp. piston after I have done a valve job and such of course. It is a stock size piston, going into a stock bore. Anyways, I was wondering about fuel consumption if I use the high comp piston. Will I need to re-jet my carb, get a diffrent exhaust system because of the power increase, and have a higher octane gasoline? Will it really add that much power? Let me know what you think. This is my first high compression project, so I need some guidance and ideas. Thanx again for the help. )
81, 85 Yamaha Tri Moto 125
83 Yamaha Tri Moto 200 x2
85 Yamaha Tri Z 250
84 Kawasaki Tecate 250
84 Honda ATC 70
85 Honda ATC 350X
84 Honda ATC 250R
(2) 84 Honda ATC 200x
82, 83 Honda ATC 185s
81 ATC 200
Lots of other parts and bikes
