Thread: Castrol 927 2-stroke oil
    Feb 2018
    Tennessee
    21
    Just wondering if any of y'all have ever used the Castro 927 2-stroke oil in the Honda 250R engines? would like to know what you think about it if so.
    Slidell, LA
    4,738
    It and klotz super techniplate are all I use. 927 castor oil is arguably some of the most protective oil you can use in your two stroke mix. Word of warning.....it likes to separate from gas so if you don’t use it quickly you will need to shake your gas cans before dumping into your tank. Also it will separate in your carb bowl if left for months at a time so make sure to drain your bowl if it’s going to sit.
    devore,ca
    1,054
    I use the 927 in my 250R. Everyone I ride with hates it because of the smell.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    6,811
    927 is all I use threw my shop as well , good stuff !!!!!
