Thread: Questions About 250r front end on 250sx !!!!!!
    Jan 2008
    Florida
    71
    I've been reading as much as I could find about this.
    Does anybody know how well a 85-86 250r front end on a 250sx handles
    And why did Dirtcrasher say it was overkill / waste of time
    I Feel Wouldn't a stronger front end be better on a utility trike ? I Use my 200s to push stuff around with the front tire !!!
    Are there conversion bearings for this :?
    I Have a Spare 250r front end wheel and all But IF it isn't even worth the time I'll just keep it for my 250r !
    or if anybody has two fork caps off of some 200x forks that would be all that I Would need to put a 200x front end on my 250sx !!!!!
    Thank you so very much I am really curious about doing this !!!!!
    Because it is, what's next, inverts on a 125M??
    Before you utilize any of the suspension travel on a 250R front fork, you'll bend the 250SX rear end components.
    200X front forks slide right in, you'll have disc brakes and can retain your stock clamps, just require a just a couple axle spacers.
    If you want to PUSH things with your front end, I suggest getting a horse or a plow instead...
    Jan 2008
    Florida
    71
    I guess I'll just leave it stock. Or find a couple more 200x parts to do the swap ! Thank you.
    Connecticut
    1,605
    Quote Originally Posted by OTAlucard View Post
    If anybody has two fork caps off of some 200x forks that would be all that I Would need to put a 200x front end on my 250sx !!!!! Thank you so very much I am really curious about doing this !!!!!
    I would find the fork caps and put the X set up on
