On a 85 Tri-z motor, on the inside of the cases the bearings used for the transmission shafts are a sealed bearing.
Is it normal for the internal bearing to have a factory seal?
Should these be removed and replaced with bearings that are not factory sealed?
Or what is the reason they need to be factory sealed inside the transmission?
Thanks
