Results 1 to 9 of 9
Thread: YTM 225 starter issue
    Feb 2018
    Indiana USA
    16
    Question YTM 225 starter issue
    Hey everyone...new to the site and 3 wheeling. Recently picked up a 1985 YTM225dx and was getting tired of pull starting it. Went to put voltage to the starter and nothing. Bench tested good...button good and I have voltage going to starter post. Stuck my finger in the hole and the gears will not turn...they look good but seem froze. On a parts motor the gear will turn. I assume the gear or starter clutch my be stuck??? Before I dig deeper what would cause this problem and how big of a deal is it to fix? Any help or insight would be great. It will start with the rope pull but it takes a long time to get it running.
    Jul 2017
    Pennsylvania
    71
    I have been working on an 84 with the same issue down to the spare motor . I took mine apart and I think the issue is the clutch. I am pulling the clutch on spare motor this afternoon to compare. It is not too difficult as long as you have a puller.
    Mar 2018
    West Lafayette, Indiana
    Cannot quite tell from your post if you have tried to jump the starter yet or not, but in the invent that you have not. Get the starter relay into a position that you can apply voltage to it. Apply voltage to the terminal that goes directly to the starter. The starter should have a ground on it already so just ground to the frame(convenient to use the battery ground). Don't run the starter to long if it starts to go. If it doesn't go then its probably the starter itself if it does go it may be the starter relay. Hope this helps.
    Feb 2018
    Indiana USA
    16
    Quote Originally Posted by Mach-10 View Post
    I've got a flywheel puller coming. Did you find the clutch was your issue?
    Feb 2018
    Indiana USA
    16
    Putting a hot cable right to the starter...it only makes a slight "clunk" noise. This I assume is the starter gear hitting the main gear that wont turn. Have a puller coming and will hopefully find out whats going on inside that case.
    Feb 2018
    Indiana USA
    16
    Quote Originally Posted by MDillon View Post
    Feb 2018
    IN
    9
    If it bench tests good and when you put it on machine and have nothing, bad ground. You mentioned you have voltage to the starter post. It should do something if you get the ground
    Feb 2018
    Indiana USA
    16
    Finally got some time to rip into the case. With the case off the starter works fine and the motor turns over. I can only assume something was in a bind...maybe the spacer on the shaft is just a tad to long and when bolted down the case is pressing the spacer against the idle gear and keeping everything from moving? The starter clutch is working so no need to pull the flywheel. Just waiting on a new gasket now. Previous owners had used blue silicone and now gasket. Maybe the gasket will give me the extra clearance needed...
    thanks for the help
    Feb 2018
    Indiana USA
    16
    Quote Originally Posted by geyerman89 View Post
    It all works with the case removed...Im thinking since the gasket was missing maybe there are clearance issues with the spacer and the gears are pinched. So I have a new gasket coming. Thanks for the reply
