Thread: Looking for 250sx differential final drive gears
    Mar 2014
    Waddington NY
    77
    So while replacing the swing arm bearings on my 86 250sx. I noticed some slop in the differential. I tore it down to flush out all the old nasty fluid, and really discovered the slop. So, when i aquired this SX, i was about 16. The rear diff was in pieces and i had to rebuild it. Ive always noticed shaving in my fluid, so im guessing my gears were worn initially and i never really noticed. Being 20 and working at a machine shop now, i know what to look for, and have alot more help. The bottom of my pinion shaft is worn out, and sloppy in the needle bearing, which wore out the pinion bearing prematurely and caused more damage to my gears. So, long story short, new gears and a new bearing kit are in order. Any help locating new gears, or possibly a differential in good shape would be appreciated! Thanks guys
    Don't worry, its a Honda!!
    Currently in my collection:
    1983 Honda 200e Big Red
    1986 Honda 250sx
    1986 Honda 350x($350 barn find, insane)
    1985 Honda 250sx
    1986 Honda 250R
    1986 Honda 250es Big Red
    1984 Honda 200s
    1983 Honda 70
    1983 Honda 110 (Blue edition) (need rear fenders and seat, whose get em??)
    1985 Kawasaki Tecate 3
    Feb 2003
    New York
    624
    Probably best to ask around the message board for someone who is parting out a 250SX diffy. I bought a 250sx years ago in a town called Silver Lake NY that was very close to the St. Lawrence River near Canada. Are you near there ? Hope you find your parts.
    ♠ 58 ♠
    Ride 3
    Mar 2014
    Waddington NY
    77
    Yes, i live right on the St Lawrence. I can see Canada from my front yard
    1986 Honda 250sx
    1985 Honda 250sx
    1986 Honda 250R
    1984 Honda 200s
    1983 Honda 70
    Mar 2014
    Waddington NY
    77
    Still looking if anybody can help!
    1986 Honda 250sx
    1985 Honda 250sx
    1986 Honda 250R
    1984 Honda 200s
    1983 Honda 70
    Mar 2014
    Waddington NY
    77
    I was able to locate a ring and pinion gear set that will fit a TRX300FW. Does anybody have any infomation if these are the right dimensions for my differential cases? And if so, is there any difference in the gearing ratio? Thanks for any help! https://www.ebay.com/itm/Honda-TRX30...1957%7Ciid%3A1
    1986 Honda 250sx
    1985 Honda 250sx
    1986 Honda 250R
    1984 Honda 200s
    1983 Honda 70
